This is normally caused by a power supply that is failing. When you turn it on the unit tries to power up and you see the screen then the power supply fails and it goes dark only to repeat the cycle.
This happens because heat build up in the monitor case causes parts called capacitors to
blow leading to the power supply short. If you can solder you should be
able to do the repair. Go to our web site at: www.ccl-la.com/badcaps.htm
We have pictures of what to look for. Now take the back off of your
monitor and replace all of the caps that look like the pictures and you
should be back going again. Be sure to use high temp parts, they will
be marked 105c. The values you will need to get will be marked on the
sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert
the new ones be sure to put the polarity stripe going the same
direction as the old one comes out. If you have any questions just let
me know. If you don't want to do the repair yourself we do offer a
repair service for $30 + return shipping.
I hope this helps, if so please rate our solution.
hi, i have just purchase a flatrun l1718s had cannot get it to work with my system, its out of...
(More)
hi, i have just purchase a flatrun l1718s had cannot get it to work with my system, its out of range, how can i fix this??
