Question about Aureal IBM LENOVO AUDIO CARD- VORTEX 09N5383 Sound Card
I cannot find sound and audio device?
0 characters
1 Points
Ther is know audio and sound in to my can i fix it?
- Go to control panel in My Computer, then go to Sounds and Audio Devices. - Go to the tab labeled audio and where it says sound playback click volume and make sure you volume control is not muted. If it still doesn't play music make sure the plug from your speakers is plugged into the green plug in the back of your computer - Make sure also to plug it from an outlet if it uses electricity
If the above troubleshooting still didn't work, go to Control Panel, then System, find Device Manager. Click the Sound, video and game controller,then right-click the soundcard installed then click Properties. Check for the device status if it is working properly, otherwise if other message status is there, try to find a new driver on the net.
Mar 24, 2011 | Audio Cards
I can only hear sound from my laptop when i plug in earphones
the drivers might have been corrupted by a virus or something foreign to your system run your antivirus program
then click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow ? question mark right click to update driver or
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Jan 21, 2011 | Compaq Audio card Sound Card
After formating ther hard drive i dont have sound device
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Acer (54.AA806.001) Sound Card
I have an IBM thinkpad and there is no!!!
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 11, 2010 | IBM ThinkPad Soundcard
1st Download Driver from this site IBM Sound Driver
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
Jun 24, 2009 | IBM (01K2154) Sound Card
The Sound of my P.C doesn't come
Connect to the internet, and get a free download of Realtek 97 audio
driver. Then, run and reinstall this in your IBM Thinkpad. Then, you
can listen again to the music and sound of your fab movies. Send us
your e-mail comment.
Jun 24, 2009 | IBM ThinkPad Soundcard
You need to re install audio card.
If this is a brand PC, or a laptop, look into the factory website, for example Dell, Packard bell, Acer, Sony, IBM, Toshiba etc.
If this is a no brand computer, and you do not have sound card, you can either try reading motherboard code inside the machine, and find drivers on motherboard website, or install a new sound card , that is not expensive.
If you cannot find the drivers, enter on google : "PCI sound adapter" or "USB external sound adapter", to find prices for a new sound card.
Jan 21, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Sound Problem
remove any fifa components from add/remove programs
Is there sound with head phones, does device manager show its working ok - search the manufacturer plus model of Your computer with sound driver after it to locate and reinstall
or check any instalation disks You got with the machine to install
if device manager shows its ok (right click my computer, left click properties, choose hardware tab then device manger - see whats listed under sound and audio devices , any red X's etc)
if it looks ok in there - open all Your audio programs, real, win media and any others make sure none are on mute and up full volume
lastly go into control panel souns and audio devices, on audio tab make sure You have Your sound card as default audio playback - - - where their any other hardwares that came with the game, i.e headsets, joypads etc that could have set themselves to the default audio devices?
Jul 18, 2008 | Audio Cards
Sound driver
Hello there.
Windows Vista has the audio driver built in. If you use Windows XP then download and run the audio driver from here .
Hope this helps.
Jun 18, 2008 | IBM ThinkPad Soundcard
Audio Cards Logo
Top Aureal Audio Cards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Teet Bergmann
Are you an Aureal Audio Card Expert? Answer questions, earn points and help others
