Question about Sansui Televison & Video
SMD TRANSISTER DETAILS
Iam a aservice technician ,i want know about smd details and its comparison type .ihave a sansui dvd player with attach 5+1 channel amplifier.it have a compliant, sometime it  will not work ,ichecked the power supply unit and system board ,finally i find the system board has the problem,the problem is the reset circuit of the the system is failure.can u tell me the value of diode [ad1] and smd transister no[rq1] also tell me the comparison type.i show below the detail of the dvd players model details and system board  details.
sansui model-[RZ-9530AVD-CP]
SYSTEM BOARD DETAILS-MODEL NO-[DMC-1030]
CODE NO-DPPB-10169C
MANUFACTURING DATE-2005-01-27
    Top Expert:
  • Sansui Master
  • 75,157 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on May 11, 2017
Maanita
  • 1142 Answers
SOURCE: IHAVE A DVD PLAYER RECORDER
Thank you for posting your concern details however i would be
needing few more details from your side if necessary and
allow me few mins to come up with the resolution.
Posted on May 14, 2008
Ajkill
  • 2035 Answers
SOURCE: RD-XS24SB HD/DVD player / Recorder
Please check if the fuse is blown out in the player and like to perform DIY on the DVD you will need a service manual to guide :
Please use this link to get one :
http://www.user-manuals.com/advanced_search_result.php?keywords=Toshiba+RD-XS24SB+service+manual&forward=plist
Good luck..
Posted on Jul 31, 2008
SOURCE: Power supply AD-12014(I) two smd burned
223 both
Posted on Mar 02, 2010
Jaketech
  • 67 Answers
SOURCE: i want the manufacturing details
This link should have what you are looking for:
http://cdgenp01.csd.toshiba.com/content/product/pdf_files/detailed_specs/satellite_A105-S361.pdf
You will need adobe reader to view it as it is a PDF file
Posted on Jul 27, 2010
SOURCE: philips dvd HTS3010 power suply
what is ic number which is give the power supply to transformer
Posted on Feb 19, 2011
What is the difference between GLC-LH-SM and GLC-LH-SMD?
They are 1000BASE-LX/LH SFP for Both Multimode and Single-Mode Fibers, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard single-mode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers.
If one switch supports Cisco SFP GLC-LH-SM, then it can also support Cisco SFP GLC-LH-SMD.
The difference between GLC-LH-SM and SFP GLC-LH-SMD is the letter "D".
What does "D" mean?
"D" of GLC-LH-SMD transceiver has additional support for Digital Optical Monitoring (DOM) capability.
What is Digital Optical Monitoring(DOM)?
This feature gives the end user the ability to monitor real-time parameters of the SFP, such as optical output power, optical input power, temperature, laser bias current, and transceiver supply voltage.
The comparison between GLC-LH-SMD and GLC-LH-SM.
Related Source:
https://supportforums.cisco.com/document/75181/digital-optical-monitoring-dom
GLC LH SMD Overview
GLC LH SM LC Overview
Aug 18, 2017 | The Computers & Internet
IHAVE A DVD PLAYER RECORDER DVD3460. I ENTER THE DETAILS IN THE TIMER AND IT RECORDS THE DETAILS AS VALID, 5 TIMES IN A ROW IT SHOWED FAILED.IT HAS ON OCCASIONS RECORDED CORRECTLY, BUT NOT OF LATE??...
May 14, 2008 | Televison & Video
Does a proton flat screen TV. ..backlight have a replacement fuse
Normally all the backlight inverters have fuse. It would be an SMd type.
Of you wish to get some more details check the link below
http://electro-medical.blogspot.com/
Jul 06, 2016 | Proton Televison & Video
Crt model tv using ic is smd r2j10160g8-a59 only two inch of screen picture is shown
Vertical scan output/oscillator problem. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 23, 2014 | Televison & Video
It has power going to the radio but the screen stays off. how can i fix it?
check a fuse in the mother board SMD type for 12volts to the screen
Sep 30, 2012 | Kenwood DDX-512 Car DVD Player
Dvd player 3280S - plays movei till about halfway, tehn the picture sticks. It seems taht teh disc continues to turn, but the picture doesnt change.
This symptom indicates that your lens motor drive chip is over heating and failing after half an hour, so the laser unit does not read further. You will need professional help as the IC ( chip ) involved is an smd type which needs very good soldering experience to remove and fix. The spare will cost about 5-8 $ plus labor.
Aug 16, 2011 | Sansui Televison & Video
HP Pavillion dv6500 Notebook. Power light coming on when connected up to charger but no charge going in.
I just fixed my friends dv6500
it had same probs as mentioned above
the probs i found : shorted schottky diode marked LG = smd10k45
                           shorted n-ch mosfet      marked 702 = 2N7002
                           defect smd cap
All these are placed just below the battery connector on mobo
see page 128 of service manual
replaced these smd's and laptop worked again
the damage was caused by overheating of the smd's
could be you have the replace other smd's surrounding these mentioned above
depends on how hot it was
hope this helps
Greetz
RzAn8
Nov 13, 2008 | Computers & Internet
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
NO DISC
Remove top of unit(make sure it is unplugged) Move laser on track to where it is visible. Clean lens with isopropyl alcohol or acetone. if there is no change, the chances are that there is an smd fuse that is open on the AtoD board. the consumer cannot access this component. Many times this smd fuse opens due to leaky smd capacitors. Unfortuneately many of these units end up in the sony boneyard in the sky. Scrivitron
Jun 14, 2007 | Sony DVP-NS305 DVD Player
Need to purchase SMD Tactile Switch(es)
Fixya does not sell or source spares, parts or components
Jul 06, 2017 | Aiptek IS-DV Memory Card Camcorder
Televison & Video Logo
94 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
