Question about Hoover PE235 Front Load Washer
Washing machine problem
We have an ancient Hoover top loading washing machine (not on the product list). When it starts a regular wash cycle it fills OK then just makes a wirring noise until it cuts out. Pressing the reset button just restarts the wirring noise.
I took off the front panel and manually rotated the bowl back and forth a bit. Then the machine works when I reset/restart.
This has happened several times. It seems like there is excess friction somewhere in the system, so that the drive belt is slipping. Is lubrication the answer and if so how?
Thanks.
    President:
  • 1,294 Answers
Sure you need to lubricate. But change the belt, you get all sizes easily. The wiirring noise is usually when the belt is off, worn out likely.
Pl rate, thanks
Posted on Dec 27, 2007
  • prem mathew Dec 27, 2007
    A thorough lube for all moving parts you can see, not the belt!!
My hoover 800rl top load washing machine does not progress beyond the fill cycle. once the water has reached the set level the start/ pause light goes from solid to flashing and nothing progresses form...
Check owner's manual. The light issue should be covered. Is it possible the tub is over filled? If so the level indicator switch is not working right. I'd unplug for overnight to see if the electronics will reset. Service Technician may be needed.
Feb 13, 2015 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hoover Elite 920 top loading washing machine will not fill. I can manually fill the machine and it will run through a cycle until fill is required for rinse cycle and then I have to manually fill again I...
first check the water is switched on to the machine. If it is then you most likely have a faulty water valve. Switch all power off and remove the top panel should be 4 screws or so. If it has 1 valve then replace it.
Mar 09, 2011 | Hoover Washing Machines
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Hoover PE235 Front Load Washer Logo
273 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
