Hitachi 43FWX20B 43 in. Rear Projection Television
Problem for Hitachi 43FWX20B 43 in. Rear Projection Television
Hitachi 43wx20b 43 in. - good picture except for
By gregoryal777 on Oct 14, 2009
Hitachi 43wx20b 43 in. - good picture except for blue haze on words and people. Magic focus does not help. Magic focus shows all three colors. Seems to me that the blue gun is not focusing properly.
Best Solution
posted on Oct 14, 2009
Very Helpful)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 1136 votes
OK--for a Hitachi this set is a little unusual---it uses two of the STK-392-120 CONVERGENCE CHIPS.
Oneor both are bad(usually just one) You need to replace both and anydiscolored resistors around them--all the resistors have locationnumbers and if any are even slightly discolored you need to replacethem and both chips---You can buy a pair of these chips on Ebay forless than 13 dollars plus shipping.
If you remove the back cover (unplug the set first!) look at the circuit boardon the far right side----about 4 inches wide and about 12 inchesdeep---the chips are on the far right side on the large metal piecewith fins.
If you look and find any of the resistors behind them(on the left side of the metal with fins) discolored---note thelocation number printed on top of the circuit board under them (RK46etc) and I can tell you the exact value of that part--most of theresistors that fail are low value and can be tested just like afuse--It is important to find any bad resistors as if you replace thechips and miss any open resistors the set will still have the sameproblem.
THIS IS A EASY SET TO DO THIS REPAIR ON IF YOU KNOW HOW TO SOLDER---I CAN GIVE YOU INSTRUCTIONS IF YOU NEED THEM.
THISKIND OF REPAIR TAKES ABOUT 1 HOUR--THEN YOU ADJUST THE SET WITH THEORIGINAL REMOTE--set should be good to go without having this troublefor 5-8 years.
Let me know if this information helps you---If you are not able to do the repair let me know and I will give you advice
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you so much. You have diagnosed my issue very clearly. I have a friend who can solder. I will pull the back panel and check out resistors. " - gregoryal777
Popular Solutions for Hitachi 43FWX20B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43FWX20B 43 in. Rear
Do you recommend Hitachi 43FWX20B 43 in. Rear Projection Television?
Answer
Answer
A friend gave me a hitachi tv with no remote. I can't find a replacment remote anywhere. It also has... (More)
Answer
picture has green tint, had same problem about 2 years ago and repairman aligned bulbs and fixed... (More)
Answer
the screen on our Hitachi is speckeled with blue dots why is this happening?
Answer
Hitachi 43FWX20 43 in rear projection TV 2002 red and green shadows on sceen. Sometimes powering off... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
