Question about EliteGroup P4VMM2 Motherboard
Display i am running on winxp. my problem is that there are times when i am booting my PC, i end up with a blank screen display with the mouse cursor displayed in the middle of the screen. after 2x or 3x boot, i will be able to start my PC but the display is somewhat dark. But after a few minutes, normal display will be restored
    Problem Solver:
  • 19 Answers
Something's wrong with the Video. That's obvious.
Could be Resolution (too High), Refresh (off), Other Video (TV Out) at time of boot.
Try, removing TV Video, if you're using, so it's not there at time of boot. I've had that problem, I had to break the connection, that means if you want TV Out, you must Shut Down, recconnect and reboot.
I've had problems with the others too, Resolution and Refresh Rate.
Good Luck,
Posted on Dec 27, 2007
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Screen is blank, but the mouse cursor moving
Please let me know if this happens while the system boots or at initial stage of booting.. (Before login Screen appears). If that is the case, then you may have to repair your OS or check for any new hardware added to the system. It wouldnt be a VGA issue as it shows the cursor movin, VGA is working fine. If this is happening after login session, It could be due to explorer.exe being corrupt or some backend process capturing the screen. Try it.. Good luck.
Nov 18, 2010 | Dell OptiPlex GX520n PC Desktop
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Hp dx2000 boot problem
Hi Robert,
please try these troubleshooting steps,
Resolving the blank screen Follow the instructions below in order to fix this issue:
  1. Remove any CDs, DVDs or memory cards from the computer.
  2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
  3. Restart the PC. NOTE: If this resolved the issue, see the Preventing the blank screen section at the end of this document.
  4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
  5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
  6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
  7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
  8. Select Safe Mode from the Windows Advanced Options Menu .
  9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
Jun 23, 2008 | Computers & Internet
Desktop and start menu is missing what can i do
Is the desktop there with no icons?
Did you put the mouse cursor down where the system tray should be to see if it was on Auto-Hide?
Did you try and right click on the mouse with the cursor anywhere on the desktop to see if a pop-up menu appeared?
Sometimes when computer games are played the game changes the resolution on the monitor putting all the icons off screen, so by right clicking on the mouse and left clicking on properties the display properties will come up and when you go into settings you can restore them.
If none of this applies to your situation then
On boot up keep pressing F8. This will give you options, pick last known good configuration. and boot up.
If that doesn't work, press F8 on boot up and choose safe mode.
If this doesn't work then the Operating System is corrupt and will have to be repaired.
Boot with winxp cd and choose repair console.
Mar 07, 2008 | Microsoft Windows XP Professional With...
BIG BOOT PROBLEM!!!!
You should have erased the system root directory,( the Windows XP installed drive). the boot sector still has the winxp boot information, but does not finds any file on the drive, were they are supposed to be.
You have to Install a fresh copy of winxp, with the winxp boot cd.
Jan 09, 2008 | Compaq Presario 5000 PC Desktop
Blank screen with cursor
MS-DOS edit command help This would bring up a blank edit screen, as long as the file is saved upon exit
Click on the above link , Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell Inspiron 1000 Notebook
EliteGroup P4VMM2 Motherboard Logo
64 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
