Question about Maytag MAH2400A Front Load Washer
Coin is stuck inside
The quarter is stuck inside the coin machine on the right side and I can't take it out. the lcd screen keeps on blinking showing "1" and "2". I tried to put another coin in but keeps on coming back in the coin return. how can i fix this? i tried sticking a knife and a coat hanger and it still wont get dislodged from the right side. Pls. i need help. thanks
  • dcbuddha Dec 27, 2007
    its in an apartment complex, my gf owns it
  • 625 Answers
Where is this machine? apartment complex? YOUR private machine?
Posted on Dec 27, 2007
    THOMAS MIERZWA Dec 28, 2007
    OK, then here's what you do. get the gf to open up the access panel using the ace key on top of the machine. inside and just below the top is a long rod with a 5/16" hex. use a socket and unscrew the rod. the coin mechanism is keyed to the front panel. lift up and out. there are NO electrical connections to the coin mechanism. once out you'll see some bars that determine how many coins are needed to start the machine. just behind the front escutcheon is a plate that moves sideways. it is held in place by a metal plate. sometimes this plate bends just enough so the slide assembly won't go in the unit.
I have a speed queen commercial washer and a quarter is stuck in the holder how do you release it
is it a slide coin mech? If so
7/16 top center of service compartment
is the slides retaining rod
Once you have access to the coin mechanism.
the coin release will move slightly outward allowing the coin to fall into the return shoot
Jan 12, 2018 | Speed Queen Washing Machines
Drop my marriage ring in to Frigidaire GLGT1031CS
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 03, 2012 | Frigidaire GLGT1031C Dryer
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
Hi i need help.with a problem comparing coins.julian has 10 coins.sue ha 5 coins. there is a total of4 quarters.sue has more than $1 sue 'scoins are worth twice as much as julian'scoins. show julian's 10...
WHERE: X=1 or X=5 or X=10 or X=50 or X=100
JULIAN: 10 = a + b
WHERE a = # of quarters held by Julian
AND b = # of X coins
SUE: 5 = c + d
WHERE c = # of quarters held by Sue
AND d = # of X coins
QUARTERS: 4 = c + a
SUE: 100 < c*25 + d*X
VALUE: (c*25 + d*X)/ 2 = (a*25 + b*X)
Try each possible value of 'X'.
May 14, 2010 | Mathsoft Solving and Optimization...
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
1/4 of Acer 5735 Screen is not working properly
You can try reseating the LCD cable but the issue is most likely a LCD failure (Replacement of the LCD required)
Oct 09, 2009 | Acer Aspire 5735 Notebook
Z11 Printe Cartridge Stuck
first push cartridge inside and then try push out side and then keep the cartridge at right place and push it inside after pushing in make sure some green light blinking and start printing it
Feb 25, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Replacing water pump in front loader whirlpool washer
before changing pump rermove all hoses and ck for coins a quarter can turn on side and block hose also ck down in pump throat 1 screw at front of pump and slide pump back to remove..pump will run $125-$160
Jun 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH2400A Front Load Washer Logo
243 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
