Question about IBM ThinkPad A31 Notebook
Laptop problem i have a ibm laptop. when switch on beep sound coming, (one long and two short) what is the problem . please
    Genius:
  • 2,985 Answers
This is probably a memory or mother board failure.
If you google for 'beep sounds' there is a list which will tell you what various sounds mean.
Either way if the computer works OK nothing to worry about.
If the computer is malfunctioning its a workshop job.
Posted on Dec 27, 2007
My IBM T41 make beep sound and turns off itself. What is happening?
You can try the steps below.
Try removing the battery and plugin the charger and try turning on.
Do you see any thing displayed on your screen when you switch on?
Please mention the beep pattern, 2 beeps or continuous beep.
Hope this helps. Good Luck
~SmokinJoe~
Aug 24, 2011 | IBM ThinkPad T41 Notebook
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
When i turn my IBM THINKPAD R50e on it just beeps 3 times then turns off
Hi:
I checked on a beep code for your IBM laptop, and the only code listed with 3 beeps is:
One long, two short beeps System board failure; Video adapter problem; LCD assembly failure
None of these codes sound like an easy or quick fix for you.
If your code is not one long, and 2 short beeps, repost and update!
Feb 10, 2010 | IBM ThinkPad R50e Notebook
2 beeps then error
This could be a few different issues. Please state whether it is 2 short beeps, 1 long and 1 short, or 1 short and 1 long, all of these are different errors. If it is 2 short beeps you should see an error code on screen(usually 3-5 digits).
If you dont see an error code it is most likely and AMI Bios error and if it is 2 short beeps your IBM has memory problems. If you have no video at all on screen you have a parity error in your first 64K of memory. First check your RAM. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Jul 12, 2009 | IBM Computers & Internet
A beep sound is coming from my laptop during booting
hi,
This is the mike sensitivity issue.
If you are using windows vista then please go in sound properties and then go to recording tab there in levels u will find microphone boost please make it zero.
if u are using xp then please make microphone mute.
May 29, 2009 | IBM ThinkPad T30 2366 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
Ibm laptop problem
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Dec 27, 2007 | IBM ThinkPad A31 Notebook
IBM ThinkPad A31 Notebook Logo
59 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
