Question about IBM ThinkPad A31 Notebook
Ibm laptop problem
I have a ibm laptop. when its switch on, beep sound coming, (one long and two short) what is the prblem? please. i replaced memory but beep sound coming. fan working.
  • 2 more comments
  • Praveen jolly
    Praveen jolly Dec 28, 2007
    thank u sir, but it is a laptop.. there is no IDE cables and cards for video and sound... i tried by remove the onboard memmorry chips also....now iam trying to replace the bios chip.
  • Anonymous Jun 16, 2008
    Were you able to fix the problem? How?
  • Anonymous Jan 07, 2009
    some time when i open my laptop a beep sound is heard 2 / 3 time and it does not start.but after whn i switch on ,off it several time it switch on.wht should i do? plz help me
  • sharafunk9
    sharafunk9 Feb 10, 2014
    speaker sound only beep sound
Whn i switch on my laptop a beep sound come 2 or 3 time .fan is on but screen is not on,after switching it several time it get started,how can this problem solve?
Posted on Jan 07, 2009
BAD VIDEO CARD
Posted on May 29, 2008
One long and two short beeps, and a blank or unreadable
LCD.
The IBM Manual Sez:
1. System board.
2. LCD assembly.
3. DIMM.
Posted on Jan 16, 2008
  • 102 Answers
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Posted on Dec 27, 2007
Why does my pc beeps 4 times and will not boot up?
Sounds like you mother board is the problem.
Did you drop it, add memory.......
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
Jun 16, 2014 | IBM Computers & Internet
4 beeps are coming in R51 IBM notebook we remove memory module but same issue.
Just Remove the Battery and connect the Power Cable.
Try to switch ON the laptop. Please confirm if its working fine now.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | IBM ThinkPad R51 Notebook
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
Turn on laptop and it gives the cursor and a blank screen plus a continuous beeping sound.can you tell me what's wrong? Mel
sorry to say but you have Memory or video problems
Do you know what type of bios its running ?
is it one long beep ? or just short continuous beeps ?
1 long beep is graphics card failure
constant short beeps is memory failure depending on motherbord manufacture
It can be fixed by you if its short constant beeping if its the long beep tho it isnt quite as eazy as you have to remove half of the laptop to get to the graphics card
if you msg back with the laptop model number i can look into this further for you
Jan 27, 2010 | Computers & Internet
2 beeps then error
This could be a few different issues. Please state whether it is 2 short beeps, 1 long and 1 short, or 1 short and 1 long, all of these are different errors. If it is 2 short beeps you should see an error code on screen(usually 3-5 digits).
If you dont see an error code it is most likely and AMI Bios error and if it is 2 short beeps your IBM has memory problems. If you have no video at all on screen you have a parity error in your first 64K of memory. First check your RAM. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Jul 12, 2009 | IBM Computers & Internet
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
T23 Won't Startup
You need PC-133 SODIMM (144 pin). This model can use two for a max of 1GB (2x512MB).
Jan 16, 2009 | IBM ThinkPad T23 2647 Notebook
Screen
According to the support website, it could either a memory (DIMM) or motherboard (System board) problem. See beep codes and what them mean here: http://www-307.ibm.com/pc/support/site.wss/MIGR-46018.html
First thing to do would be to remove the memory and put it back in (called 'reseating') to make sure there is a firm connection to the motherboard. Find out how to do this for your particular model here: Click here. If you have two memory modules installed and the remove/reseating action did not stop the beeping, try removing just one and attempt to boot the system.
  • If you get the same beeps again, remove the one you have installed and replace with the one you took out - try booting.
  • If you don't get the same beeping and you can then boot in to windows, then you've identified the bad memory module. Replace it.
If you still get the same beep code, then it sound like it's your motherboard that needs to be replaced.
Jun 10, 2008 | IBM ThinkPad T20 2647 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
Laptop problem
This is probably a memory or mother board failure.
If you google for 'beep sounds' there is a list which will tell you what various sounds mean.
Either way if the computer works OK nothing to worry about.
If the computer is malfunctioning its a workshop job.
Dec 27, 2007 | IBM ThinkPad A31 Notebook
IBM ThinkPad A31 Notebook Logo
363 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
