Question about Pioneer AVIC-D1 Car Video Player
AVIC D1 back light/ touch screen not working
My car was in the shop for some time and needed a jump start. After the car was jump started, the backlighting and touch screen would not work. You can see the diffrent LCD reactions of menue changes but it is not back lit and you can not activate the touch feature, the music plays on the CD.
Thanks for any help I get
  • 2 more comments
  • Anonymous Jan 24, 2008
    i have the same problem same situation
  • Brendt08 May 04, 2008
    i have a similar problem, but the touch screen works fine. I just can't see anything unless sunlight is hitting it just right. I've tried to reset the unit and looking for loose connections, but neither of those proved any help
  • seo155 Sep 17, 2008
    It's actualy happened again after a repair by panasonic. Both times happend with a jumpstart. It looks like the AVIC D1 is real sensative to power surges.
    The report from panasonic on the first problem said it was a blown fuse. They cleaned it up and replaced the fuse. $200 flat fee. yeah its a fuse but no clue on if its propriatary(sp) or not but $200 none the less.
  • Anonymous Mar 06, 2009
    dark screen
    Problem Solver:
  • 18 Answers
The problem is likely FU1821 located on side B of the main system board. the part number is CEK1257 cost is about $10, it is a fast blow 2A fuse. Replacing this yourself will require some fairly good soldering skill, as this is a miniature surface mount component, it doesn't just plug in to the board. I ordered mine from partsearch.tigerdirect.com ; but there are several sites that offer this proprietary part, I was able to replace it without incident in about 1 hour using a small soldering iron, forceps (to hold the tiny fuse in place), and a desoldering tool.
Posted on Mar 05, 2009
Me 4.. anyone know any solutions? a possible fuse??
Posted on Sep 17, 2008
Avic-d1 no response from right side of touch screen.
you probably need to replace the touch screen switch assy.
Apr 26, 2010 | Pioneer AVIC-D3 Car DVD Player
Touch screen doesn't work in some spots on my Pioneer AVIC-D1 GPS system.
THIS IS A COMMON PROBLEM WITH THIS UNIT. A PIECE NEEDS TO BE REPLACED INSIDE IT. CAN BE FIXED FOR $175. INQUIRE AT OUR SHOP
WWW.AUDIODEZIGN.COM
Jan 18, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Avic-d1 video
no he's wrong the D1 cannot play DVD's from the unit
Apr 01, 2008 | Pioneer AVIC-D1 Car Video Player
Avic-d1
I had the same problem.
I found that resetting the AVIC-D1 with the engine running functioned differently tjhat wirth the engine off. I first tried pressing the reset thit the ignition on and the engine off, but that didn't fix the problem.
I did a reset with the engine running and the parking brake set and the open button started working again.
Good luck.
Feb 07, 2008 | Pioneer AVIC-D1 Car Video Player
Avic d1
I AM ASSUMING THAT YOU HAVE A BACKUP CAMERA CONNECTED AND IF SO YOU COULD TRY RESETTING THE UNIT BY EITHER PRESSING THE RECESSED BUTTON ON THE FASCIA OR REMOVING THE POWER FOR A FEW MIN'S OR THE TOUCH PANEL MAY HAVE BECOME OPEN CIRCUIT WHICH WOULD REQUIRE REPLACEMENT
Nov 21, 2007 | Pioneer AVIC-D1 Car Video Player
Recalibrating touch screen
Use the pin hole reset button.
Oct 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Avic d1 touch screen issue
The touch screen calibration is of, the screen has to be changed.Its 200$ from pioneer or you can look on ebay theres a place in ct. that will do it for 125
Sep 28, 2007 | Pioneer AVIC-D1 Car Video Player
Pioneer AVIC-D1 Car Video Player Logo
4,144 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
