Acer Aspire 4520-5582 PC Notebook
Problem for Acer Aspire 4520-5582 PC Notebook
I was using my Acer 4520 laptop, when it just
By cmomoney on Oct 14, 2009
I was using my Acer 4520 laptop, when it just turned off. It didn't shut down, just turned straight off. When I tried to turn it back on, the power button light, caps/num lights flash, the nothing. When the charger is plegged in there is no charger light.
Comments:
Oct 14, 2009
- The charger and battery work fine (I actually have two of these laptops and tested). If there is no damage to the mainboard/processor, should the laptop work properly after clearing the heatsink fans?
Oct 14, 2009
- Thanks for your suggestion. I will try and report.
Best Solution
posted on Oct 14, 2009
Very Helpful)
parrotheadpc
Rank: Guru  Acer Computer Hardware  Expert
Rating: 89%, 593 votes
When there is a sudden drop off like that it may be two reasons....first the charger died and is not putting out the correct voltage to run and charge the laptop, the battery may be wesk and would not last long enough to signal an alarm....or the ventilation grills, ports and van openings are clogged with dirt, dust and debris and you need to get a few cans of compressed air to blow all these openings out to clear up the heatsink fans. If this laptop has been run and has overheated, just realize that there may be irrepairable damage to the processor or mainboard.
Comments:
Oct 14, 2009
- Here is what is troubling me with the incident....the laptop will not power up. Look at your system varefully, is there easy access to the heatsink of the processor? If there is an access door that gives you access to the heatsink, unscrew the heatsink hold-downs and gently lift the heatsink away, clean the old thermal paste off the heatsink and on the head of the processor. Apply new thermal paste, about the size of the head of an eraser and spread it across the surfaces thinly. replace the heatsink and tighten down. There is no way of telling at this point if the mainboard is terminal. All you can do is try the steps and hope that they work. There is one more thing to do, remove the Cmos battery for 30 minutes or longer to make sure everything gets reset. If the laptop powers up, boot into the bios and the time and date will have to be reset before loading anything else. Good luck with it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Acer Aspire 4520-5582 PC
Questions and Unsolved Problems for Acer Aspire 4520-5582 PC
Do you recommend Acer Aspire 4520-5582 PC Notebook?
Answer
Answer
acer aspire 4520 no se apaga, se reinicia
Answer
I have a T42 IBM laptop, and its screen turns black whenever I remove the charger. Why?
Answer
Hello I have Acer 4520 AMD athalon 64* X2 Laptop. I was having a problem with my DVD drive, it wont... (More)
Answer
how large of a hard drive will the acer aspire 4520 mother board acept
Answer
no output display. it cant proceed the power signal. the fan is turning off after a second. pls.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
