Garmin nuvi 200W GPS Receiver Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get the location of a store that I know exists. I have a garmin nuvi 200w thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
3633
Points
20
The maps are actually provided by navteq and not all stores appear on the poi database as these need to register to do so, but third party pois are available and may include the information you require which can be loaded by using the garmin POI loader http://www8.garmin.com/products/poiloader/
TO Lady
Level 3:
  • Garmin Master 638 Answers
  • Posted on Oct 14, 2009
TO Lady
Garmin Master
Level 3:
Answers
638
Questions
Helped
238494
Points
1156
Commercial locations are gleened from advertising medium, such as Yellow Pages, etc. If the store is very small, there's a chance they won't be listed as a Garmin point of interest. You might have to search via address.
1helpful
I still cannot upload my own jpeg photos into my Garmin 255. Anyone know how to do this without using the memory card? Thanks! -bipperino
Yes, it's done the same way as adding music files to Nuvi's that have a MP3 player. Please see this link, however paste the pictures (.jpg format) into the existing JPEG folder already on your Nuvi that contains pictures installed by the factory.
http://www.sharc.net/discus/messages/6/276.html?1251991003
- Jim
tip
Garmin Nuvi 200W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi Hard Reset Here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
tip
Garmin Nuvi 200W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
Backup & Restore Nuvi Favorites here.
My garmin gps cannot locate a satellite
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
1helpful
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
tip
Download Nuvi 200W Manual Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Have you lost your Users Manual or the Quickstart Guide for your Garmin Nuvi 200 or 200W GPS?
Would you like a digital copy of the Owners Manuals for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
____________________________________
Garmin Nuvi 200W Favorites Backup here
tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi
hi plz let me know how to unlock garmin nuvi 200w. thanks.
2helpful
5answers
Garmin Nuvi 200W
Hi!
This link will let you download ALL the manuals for this Garmin unit, not just the quick start:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00656-10
I didn't convert it to a Tiny URL, so make sure the whole link shows in your browser.
I would certainly appreciate a FixYa rating from those of you looking for the library, should you deem it appropriate. Thanks!
Bob
2answers
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
