Question about Lite On LVW-5005 DVD Recorder
No Response To Open Button on Remote
The recorder works fine using the Guider Function, but I can not get the Disc Drawer to open so I can change DVDs.
  • gfrank Dec 27, 2007
    This has been a great recorder for more than two years. This is the only problem I have had. Hoping there is a simple solution.
I had the same problem- the door would not open.
I opened up the unit removed the drive and discovered a lever which allows to manually eject the tray. After playing with this a bit, I discovered that if I hit open on the until and depress this lever, it would open reliably. Not ideal, but at least it gives me ability to open/close.
Unfortunately once I put the unit back together, it no longer recognizes any disks. I must have damaged some disk sensor mechanism in the process. On the bright side however, it open/closes reliably now, doesnt even require the lever to be depressed manually. So if I can just get it to recogize disks, I am in good shape again.
You may not need to open up the unit and remove the CD burner to get to the manual lever, but you have to remove the fancy cover plate for the tray to be able to access the lever. The cover plate on mine is silvered and says "All write". The lever is on the underside of the tray to the left side, a paperclip might be able to poke thru to access it without removing the whole front cover.
Good luck.
Posted on Dec 29, 2007
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
Jan 19, 2010 | Televison & Video
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
DISC WILL NOT EJECT
Don't know if this will work for you, but I unplugged the player then plugged it back in again whlie holding down the power button. The player did not power up until I released the power button and pressed it again. That did it.
Dec 26, 2007 | Panasonic DMR-EH50 DVD Recorder
Gateway AR-230 DVD recorder
I read about some magnetic thing failing as the unit gets older. Mine does this sometimes and I gently tap top of unit as I hit the eject button. Works on mine so far.
Oct 09, 2007 | iLO DVDR05 DVD Recorder
DMR-E50 won't eject disc.
Nope sorry no quicky fix here
Sep 19, 2006 | Panasonic DMR-E50 DVD Recorder
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
147 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
