Question about Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
Has anyone tried connecting a PS3 to this tv with any success? Im having a hard time connecting it. I purchased an HDMI to DVI cable but no picture or sound. Can anyone help?
Thanks
  • 1uhde Feb 05, 2008
    Same issue. I think the DVI input is defective but I am in the same boat. It sucks.
I'm also in the same boat... I bought a Monster ULTRA SERIES 800 HDMI TO DVI VIDEO cable all excited to use my w3000... and no dice. thanks for the resolution folks - component cables here I come...
Posted on Apr 19, 2008
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Posted on Apr 02, 2008
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
This unit does not have a HDMI cable in put . Is there a cable adapter to accomplish this?
You do have a DVI input for this Dell W3000 so to connect to a box that has HDMI you will need a HDMI to DVI cable. When you connect to a cable/DVD or satellite box via HDMI/DVI you will have to run separate connectors for audio as this setup wont pass sound to the TV. Please take a moment to rate my answer. Thanks...
Here is a link to look at the cable type you will need.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2
Nov 24, 2009 | Dell W3000 30 in. HD-Ready LCD Television
I have a Zenith R57W46 TV, I am trying to connect the HDMI (From a Dish Network VIP211), to the DVI connection on the rear panel of the set, I purchased a cable that is HDMI on one end and DVI on the...
You are infact doing everything correct. More to the point and sad to say, it is the HDCP which is causing your problem. There are long drawn out explanations regarding upscaling and resolutions regarding your TV set, but to be brief, there is no proof that connecting via HDMI or DVI will actually produce any better a picture on your set than component cables. I have a sort of similar issue with my samsung 65 rear projection Tv and my PS3. The ps3 has HDMI out and my TV had DVI in, but it actually has a better picture without using those connections. I tired with an adapter for HDMI to DVI and it did work, but nothing of great quality that I had expected. With the right component cables and the correct set up on your TV, your picture should still look very sharp. I hope this helps and good luck.
Oct 27, 2009 | Zenith R57W46 57" Rear Projection...
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Dell w3000 has green power on no video just audio only
Had same problem as described by others, green light, audio, but no picture. Decided to look inside. Layed the TV face down on three textbooks (1 at top & 1 at left & Right) so that back (9 large screws & 2 small screws) could be removed along with stand. From the power supply (board that 110v AC plugs into) there is a cable connected to a circuit board on the left (again looking from the back of the TV) covered by metal shielding. Unplug this cable clean the male contacts with a miniture wire brush (bought mine at Home Depot) & plug the cable back into the socket. With rubber gloves (just to be safe) plug the AC cord into the back of the TV & wall and turn on your TV. The bulbs should activate in 7 - 8 seconds. Reassemble the back of the TV & install the stand. Enjoy your TV Doug
Sep 08, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 30 in. HD-Ready LCD Television Logo
410 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
