Question about HP LaserJet 1020 Printer
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
  • linapapa Jan 11, 2009
    how can I remove cartridge?
  • Anonymous Mar 12, 2014
    EPSON PRINTER PAPER JAM, FIXED, BUT NOW PRINTING BLANKS!
  • HP Master
  • 1,113 Answers
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Posted on Dec 27, 2007
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Paper jam
On the following video you get step by step directions
to solve your problem.
Feb 12, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
Paper jam in hp laser Jet 1020 printer
Sir/Madam
I suggest You Please Watch Below YouTube Link URL To Fix Your HP Printer Error:
http://www.youtube.com/watch?v=M4BJ-0A029M
Or
In case You still need Online Support For Hp Printer Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 1020 Printer
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
Printer will not print...it jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
Hp laserjet 1020 cant print and did feed the paper
that happend to me once you need new ink cartereges or get a macanic in
Jul 29, 2009 | HP LaserJet 1020 Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
Oct 21, 2008 | HP LaserJet 1020 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Printer problem in hp laser jet printer 1020
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
Jan 29, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
427 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
