Dell Latitude C640 PC Notebook
Problem for Dell Latitude C640 PC Notebook
"Diagnostic Boot Selected" problem on power-up boot
By kmgfmg56 on Oct 14, 2009
I've got a Dell C640 laptop that has recently developed the consistent
"Diagnostic Boot Selected" problem on power-up boot. Normally you only get this
by pressing the Fn or "i" button during power up, or by using F12 and purposely
selecting Diagnostic Boot. I get it all the time without pressing anything
extra.
Solution #1
posted on Oct 14, 2009
Not Rated)
anandsharad
Rank: Guru  Dell Expert
Rating: 93%, 57 votes
its the problem with the keyboard. make sure Function key is not pressed while turning on the computer. normally it happens only then. if the problem presists try reseat the keybaord. to see how to reseat the keyboard.
NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries.
NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer.
  1. Remove the hard drive.
  2. Turn the computer over, and remove the five M2.5 x 12-mm screws labeled "circle K."
  3. Turn the computer over and open the display.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Be careful when removing and handling the keyboard.
  1. Remove the center control cover:
  2. Insert a small, flat-blade screwdriver or plastic scribe into the notch at the right end of the center control cover and pry up the cover.
  3. Lift the center control cover up and away from the bottom case.
  4. To release the keyboard from the palm rest, use a small, flat-blade screwdriver or plastic scribe to pry up the right edge of the keyboard near the blank key.
  5. Lift the keyboard straight up about an inch and then rotate it forward toward the front of the computer, until the key face is resting on the palm rest.
NOTICE: Do not pull on the keyboard flex and track stick cables.
Pull up on the keyboard connector to disconnect it from the keyboard interface connector on the system board.
Remove the keyboard from the bottom case
See the images below for ready refference
To repalce the HDD see the image below
I am sure this will fix the computer. Because in this you are reseating the HDD as well. all the best.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude C640 PC Notebook
Questions and Unsolved Problems for Dell Latitude C640 PC Notebook
Do you recommend Dell Latitude C640 PC Notebook?
Answer
Answer
no sound for the NEC LaVie LL370/f
Answer
I had eee pc 1000h,it showed wirless connection but not show web page
Answer
drivers for integrated cameraof NEO GL31 laptop with Genuine Intel(R) CPU T2400 @ 1.83GHz
Answer
Amilo Li 1705 replaced 1GB (2 x 512 Mb) with two x 1GB ram. System still only sees original 1GB Ram... (More)
Answer
Is the cd drive read only? If I put in a blank CD, I get a pop-up which prompts me to insert a CD.... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Windham, ME
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
