Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Peavey PR10PN Powered Loudspeaker
How do i daisy chain Peavey PR10PN Powered Loudspeaker?
    Problem Solver:
  • 12 Answers
You mean a series connection, I'm assuming that you are connecting two speakers to one channnel (the right or left ) of the stereo. you take the positive and the negative leads and you put one on one speaker and the ohter on ther other speaker, positive (+) to positive (+) and negative (-) to negative(-). then you simply connect the 2 leftover connection of the speakers together with a wire. Be carefull though becaus if you do it wrong, it could short out your stereo or it will sound really bad...
Posted on Jan 07, 2008
I can't seem to independently control effects on my mains AND monitors.
We'll need the make and model of your mixer in order to help you.
May 28, 2016 | Music
Cannot daisy chain when i try speaker goes dead
This is not correct. Call Peavy at Meridian and ask them. The PR-12 is intended to be Daisey chained... I know it well. If you bought it (them) new, it should be straight forward. If you bought it used someone may have tampered with the second 1/4 " phone plug in the back. The 1/4" phone operate in series, so this couldn't be a resistance issue; i.e., Ohms.
Mar 12, 2015 | Peavey Pr 12 Loudspeaker
How to fix extra speakers to peavy xr 886 and get the same power to each sperkers not just daisy chain each extra speakers
This powered mixer can only drive 4 ohms a channel...two eight ohm speaker cabinets daisy-chained makes one four ohm load. Ampifier wattage output ratings are usually higher driving four ohms than eight BUT never drive a lower rating than advertised by the manufacturer.
If you need more power than the mixer can provide, connect the "Master Out" or "Mono Out" connections (next to the speaker output jacks) to an external power amp. Connect additional speakers to this external amp and you're done.
Nov 12, 2013 | Audio Players & Recorders
I'm a guitar player, never had to mess with the PA system. I needed to come up with a monitor system to work with a non powered mixer used for powered mains. I can't afford good powered speakers, so I...
This mixer will run 2 8 ohm cabinets per side, if this is an older unit, it has only one NL2/combo jack per channel....with the button on the front panel in the Main Monitor position you can run 2 main cabinets and 2 monitor cabinets, you will have to daisy chain your speakers.All speakers powered from the back of the unit must be passive, no powered speakers.....if you want to use this head just to run moitors and run a pair of powered mains then connect the jack on the front that says main out to input of your powered speakers, hopefully your powered speakers can be daisy chained at low level, then if you want to use the 8600 to power only monitors, get a 1/4 in y cable and plug it into monitor out on the front of the mixer and then plug it into PA 1 and PA 2 to the right there and both sides will now be the monitor mix from this mixer and it will run 2 speakers per side, as long as the cabinets are 8 ohms.
Oct 09, 2013 | Peavey XR Series XR8600 Powered Mixer
Hi i have 2x ev sx300 speakers (speakon) and 2x peavey es 315 (1/4 jack) can i daisy chain the ev's from channel a and the peavey's from channel B (all speakers are 8 ohm). Also should speakon...
Yes, you can put two 8 ohm speakers daisy chain per side MAX. The Speakon should have ONLY two wires on the +1 and -1 terminals unless you are using bridged mode which is NOT applicable in your configuration of speakers. Also be careful is you use any 1/4 inch speaker plugs in the sytem as the SLEEVE, not the TIP of channel A is the "hot" lead... get this to ground someplace and goodbye amp.
Jul 03, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
Daisychaining subnets?
It is not recommended to daisy chain subnets because the flow of information is slowed as well as transfer of information But if done properly by using routers as well as correctly identifying the flow of information with the use of static routing then that is the correct way of daisy chaining subnets.
Nov 26, 2008 | Computers & Internet
Open Questions:
Car Audio & Video Logo
71 people viewed this question
Top Peavey Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
