Question about HP OfficeJet 4255 All-In-One InkJet Printer
Fax mode not separating fax and phone
Can i pless have ano of your
Posted on May 07, 2008
Phone line and fax machine
ou may have inadvertently changed it from "Auto Fax" to "Manul". From the Xerox knowledge base website at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=12,E=0000000000022752235,K=612,Sxi=13,Case=obj(18044)
Print the fax received in manual mode by:
When a fax is received, your machine sounds the ringer. Then you will hear a fax tone. Press On Hook Dial and then Start Copy/Fax. The machine prints the fax and returns to Standby Mode when the reception is completed.
To change back to "Auto Mode", follow the instructions at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=53,E=0000000000022752268,K=612,Sxi=14,Case=obj(18040)
Jan 07, 2014 | Xerox Office Equipment & Supplies
Problem with the F/T setting.
leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
Jul 29, 2008 | Office Equipment & Supplies
Using on voip
If your VOIP adapter has only one service line (VOIP PIN configured) then you have to remove the phone line and connect the FAX line. Now if you have the two service lines (in the both port separate VOIP PIN should be configured) - then you may connect this FAX to the other port. Both (Phone as well ad FAX) will work simultaneously. (Remember - two seperate PINS are required if you attach phone as well as FAX line in same adapter). After attaching the FAX - every think is normal like normal FAX line. Generally you don't have to dial pre country code like 011 or 00 or +, just dial the number starting from Country code.
Jun 06, 2010 | Brother FAX-575 Plain Paper Thermal
Can I use my phone number as my fax number?
Yes. Use a splitter. If fax has fax switch built in then fax calls should go to fax only and not phone. A fax switch can be fitted separately.
Nov 17, 2009 | Brother IntelliFAX 1840C Plain Paper...
Hp offfice jet 6500 can send fax cannnot receive them
Do u have separate phone line for fax and phone ?
the phone cable which is attached to the printer , it should be two prong cable..
Do you have answering machine attached to the all in one..
if yes then try changing the rings to ans of the printer.. it should be 2 more than the ans machine..
and in fax settings on the printer.. you will find an option in advance fax settings of ECM ( error correction mode) turn it off..
then try to send or recieve fax
Oct 20, 2009 | HP Officejet 6500 Wireless All-in-One...
Do I have to have a separate line for the fax on a epson stylus cx5800f, or can I use the same phone line that my phone is on.???
You can use the same phone line as your voice line. The only thing will be if the fax is in auto answer mode then it will answer the phone when anyone calls you. If you want to go this way the best setup would be to configure the fax machine to not answer (manual mode). Now the machine can send faxes anytime you are not on the phone and if you get a fax call when you answer and hear the fax tones just push the receive button on the machine and it will answer the fax.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Office Equipment & Supplies
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Vonage Again
Just use a splitter and connect the phone line direclty to officejet 7310 All-in-One line 1 port.
Then make below changes :
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off.
Thanks
Dec 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax query
This sounds like you have smart ring on your home line. Smart ring lets you have 2 seperate telephone numbers, One for fax and another for phone, but 2 distinctive rings all one one line. Check your manual to see if you have this feature and to set it up.
Jul 10, 2007 | HP 920 Plain Paper Fax
HP OfficeJet 4255 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
