Question about RCA WHP141 Consumer Headphones
I can't open the battery compartment - RCA WHP141 Consumer Headphones
  • 1 more comment
  • Bobby67 Dec 27, 2007
    Same problem - can't open battery compartment. Finger depression way too small, plusit must be stuck or stripped. My 6'5" son-in-law couldn't budge it either.
  • valerra Dec 30, 2007
    the same problem - It is hard to open the battery compartment
  • Pooky Bear Dec 31, 2007
    I had to gently pry it off with a razor blade. Minor scratches but very hard to see them.
Had same problem. Try pressing the heel of your hand on the battery compartment lid and rotate. Worked for me.
Posted on Dec 31, 2007
  • billarnold Jan 16, 2011
    Try a balanced pressure, not too hard, not too light. I practiced several times and now can open the compartment easily.
This is ridiculous. How can RCA be so ignorant? That, my friends, is why Apple is a kick company. And (most of) the others are just jackasses.
Posted on Dec 09, 2012
I couldn't open the battery compartment because it stacked. I put around all the compartment groove a little bit of machine oil and left for 10 min. After this I managed to shift the compartment cover and taken it off with help of my swiss knife blade (just touch).
Vladimir Z.
Posted on Mar 02, 2008
  • 2 more comments
  • Donald LaPointe Nov 13, 2012
    Same problem here. Finger or palm of hand won't work. Now trying the oil. You would think there would be a phone number we could call as this obviously is a PROBLEM.
    5 stars to Vladimir56!!! The oil worked. Was able to open the battery compartment by using my finger nair where a finger was suppose to work. Thanks Vladimir56
  • klement
    klement Dec 27, 2012
    Great advice!! I didn't have any machine oil so I used vegetable oil. Worked in a matter of minutes. Thank you!!!
  • Paula Lancaster
    Paula Lancaster Jan 21, 2013
    Using the oil worked just great, thank you so much, have a nice life!!!
Can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
Rear Compartment Lid
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
Jan 01, 2017 | Cars & Trucks
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Just replaced batteries camera is brand new and wont turn on
    Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
    Jul 18, 2010 | Canon PowerShot A490 Digital Camera
    Opening battery compartment on Midland LXT80 2-way radios
    First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
    Jul 07, 2010 | Midland LXT80 Two Way Radio
    Need to replace internal clock battery
    This may have been solved by now however...
    REMOVE MAIN BATTERY... Before Opening any compartments!
    The CMOS battery is located in the modem compartment.
    Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
    Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
    Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
    Battery compartment in Magellan SporTrak
    I used a Dremel Tool with a small drill bit to drill it out without killing the threads. It then popped out. My only problem now is finding a screw that fits the threads....
    Jan 28, 2009 | Magellan SporTrak Map ATV GPS Receiver
    Cassette am
    To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
    Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
    RCA WHP141 Consumer Headphones Logo
    1,153 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
