Back to:
Tags:
Polaroid FLM-2601 Television
Power problem - Polaroid FLM 2601 (by 3 users)
posted by carbon1 on Dec 27, 2007
my Polaroid FLM 2601 wont turn on. it's just in the standby mode. pls help! thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Joes1, posted on Feb 02, 2008
Power light comes on but no picture or sound, pulled power supply apart has 35v caps in it?, if any has a service manual i would like to repair it, Thanks.
Comment by treschiq, posted on Jan 27, 2008
Same problem.. The poloraid flm 2601 will not turn on. The red light stays on and that's it. I called fox International and they stated they do not carry poloraid parts?? Any advise would be appreciated
P.s I called Poloraid and the 2 numbers they gave me for parts were out of service
Best Solution
posted on Feb 21, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i called polaroid and they sent me a power supply for free! go to their site to get the number.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on power problem - Polaroid FLM 2601:
I don't want to Accept this solution
Solution #2
posted on Feb 04, 2008
Helpful (85)
Joes1
Rating: 85%, 2 votes
1-866-921-PART (7278) TigerDirect has the power supply i just called and ordered one. It is for a Advent Tv but is the same part number. Original number is 667-L27M6-20C there number is 6LM00220C0. Hope this helps.
Thank You!
Solution #3
posted on Feb 20, 2008
Helpful (85)
gmikulski
Rank:Guide Guide
Rating: 86%, 12 votes
i just repaired mine by replacing the 2 electrolitic caps that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
Thank You!
Solution #4
posted on Dec 27, 2007
Thanks for Trying (70)
premtech
Rank:Guru Guru
Rating: 89%, 858 votes
The Flm2601 is plagued with a poorly designed SMPS and needs to be replaced... The ONLY outlet selling those is Fox International and the PS model number is #MLT166A... I do have the manual for that PS but it won't do much good - it usually buldges several 16v caps when it goes then goes into a domino failure...
Good news is the supplies aren't expensive, I think the last one I bought was around $70.00 dollars and it's a plug and play.
Toll Free Sales 1-800-321-6993
Bill
Rating Locked! (?) carbon1 has rated this solution as Thanks for Trying
Thank You!
Can you Help with these Flat Panel Televisions problems?
Whenever we are watching a program that has a sort of...
my Polaroid FLM-2061 is a HDTV. Does that mean it is HD...
32" Polaroid TV LCD picture cuts off
I just repaired mine , Wouldn't power on and replaced 2...
I want to clean inside and change out the power supply in...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
