Fujitsu 24C1 Air Conditioner
Problem for Fujitsu 24C1 Air Conditioner
Ffdsgfgdnfgn
By shabs541 on Oct 14, 2009
when i turn on the air con it only blows heat even when its on cooling mood.
Clarification Request
Posted by www_roxierec on Oct 17, 2009
both remotes calling for cooling ,when running amps and pressure appears normal supply air @ 13c.both uint will stop and start blowing warm air although room temperture @30c
Solution #1
posted on Oct 14, 2009
Not Rated)
rolingking
Rank: Wiz
Rating: 84%, 205 votes
It only mean that you have to check your refrigerant load. First, you must check for leaking refrigerant line. Then, you can load the right amount of refrigerant to get the right cooling. I am sure you will
get a good result. Send in your e-mail for your comments.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 24C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 24C1 Air Conditioner
Do you recommend Fujitsu 24C1 Air Conditioner?
Answer
Answer
can not see screen, and do not know how to change battery
Answer
Internal unit timer light flashes twice then pause and repeats itself. outside unit does not come on... (More)
Answer
Which picture do I need to cool the house with a fujitsu ducted air conditioning. The picture of the... (More)
Answer
the end of the louver is broken and need louver parts
Answer
The lights flashing on the unit are the yellow and red. When powered off, it does not turn off. We... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 24C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
