Question about Sony KP-51HW40 51" Rear Projection Television
TV is messed up
The color on the screen are all messed up. and the picture seems to be going inward. the colors seemed messed up a while back but now its like all getting messed up
help!!??
  • ehh1 Dec 28, 2007
    ok i have provided three pictures. pleas tell me whats wrong and who can i contact to get it fixed, or is it even fixable..thanks
    Image and video hosting by TinyPic
  • ehh1 Dec 28, 2007
    uhm so that didnt work..
    here..
    http://i5.tinypic.com/6khiyhy.jpg
    http://i14.tinypic.com/6usfs4j.jpg
    http://i16.tinypic.com/8fd0f3t.jpg
    Genius:
  • 1,139 Answers
Hello ehh1,
Can you provide a photo of the screen. It would help with the diagnosis.
Thank you
Posted on Dec 27, 2007
  • Henry McKelvey
    Henry McKelvey Dec 28, 2007
    Hello ehh1,
    It looks like you have a convergence correction amplifier problem. There are two of these attached to a heat sink on or near the HV section of the deflection board. These two Integrated Circuit Modules have to be replaced along with the bias resistors attached to them. I would suggest that you have a qualified TV technician do this, because I have seen folks try to replace these components themselves and create bigger problems. However if you are planning on doing this yourself, Get a schematic to let you know what the part values and numbers are. Desolder and remove the ICs making sure not to short out any of the pins. Desolder and remove the bias resistors, then purchase the correct ICs (as shown on the front of the ICs), and bias resistors. Install the ICs (making sure to use silicone heat transfer paste on the side facing the heat sink), and the bias resistors and solder them in place (Making sure not to short out any thing) then cut the leads to the solder level. Use a magnifying glass to check the connections prior to turning the TV on. Again I stress MAKE SURE YOU CHECK THOSE CONNECTIONS YOU MADE WITH A MAGNIFYING GLASS!!
    I hope this helps,
    Thank you,
    Shuttle83
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
I have a couple issues. First, my screen is yellowing from the sides inward, and second, the picture seems a bit "blurry", even though it's set to 1080i and getting a signal from an HD...
The tv have a problems known as a convergence pictures problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes all of these problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 31, 2011 | Samsung HCM5525W 55" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
I have a JVC 48' widescreen tv approx. 7 - 8 yrs old. the picture is now extremely bad all of the colors seem to be out of wack and the picture bows inward toward the middle at the top and bows inward...
There's a miror or one like this might have a ''aluminium sheet'' miror.
Open the upper back cover to see what going on there, pretty sure something run out of place...
Sep 08, 2009 | Televison & Video
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Color Problem
Im having the same proplem with a tube set.If it is projection,you may have to replace your convergance chips if it is a tube I my self Am waiting for,I hope it has a degousing program.
Sep 22, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
