Most likely you have a power supply problem. Capacitors go bad in the power supply causing voltages to fluctuate when the set is trying to start. Have a repair shop check it out.
take off back cover set household fan aimed at back, if problem goes away cut hole in back cover and mount a quiet computer fan. Worked for me!!!!!!! I looked through 1,000's of posts, usually picture goes off after about a half an hour then every five minutes after that.
Philips 42PF9630A remote control "channel button" no longer works. Also power button only...
(More)
Philips 42PF9630A remote control "channel button" no longer works. Also power button only turns TV OFF but not ON? Any idea, can I fix it? Thank You.
is there any fix to my philips plasma 42"..still does a clicking noise when turn on then show 8...
(More)
is there any fix to my philips plasma 42"..still does a clicking noise when turn on then show 8 blinking red lights ?
Im looking to purchase a used 42PF9630A. The owner said the tv had been dead and replaced a board,...
(More)
Im looking to purchase a used 42PF9630A. The owner said the tv had been dead and replaced a board, once that board was replaced a series of black vertical lines appeared (3-5 inches on the left hand side, followed by two more 1-2 inches), in between the black lines the picture is showing as normal. He sent me a link for a logic buffer board. My questions are 1. is there a way to know if replacing this board will fix the problem? 2. is this a screen replacement issue or driver , etc. and is there an absolute determining method or way to tell? I have pictures if needed.
We have a Philips Plasma en when I put it on with the remote control, the tv goes on and directly...
(More)
We have a Philips Plasma en when I put it on with the remote control, the tv goes on and directly afterwards goes in standby again. I afterwards always have to pull out the plug. There is probably something wrong with the feeder box?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
