Question about RCA RS2652 Shelf System
No bass... i got the stereo less than six months ago and one day when i started it up the subs( the 2 bigger speakers) just didn't work at all. only the smaller speakers were working so all you hear is bland music without the bass... can somebody please help me with this... tnx
  • namnit07 May 24, 2008
    The subwoofer on my right speaker went completely out. i tried reconnecting the wires in the back but nothing changed. HELP!
  • Anonymous Apr 24, 2009
I have the same problem
Posted on Feb 01, 2008
See u have to have the wires plugged into the black and gray ones other wise becuz the others are treb it won't have any bass
Posted on Feb 14, 2008
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
I have 2 infinity kappa speakers in the rear deck of my car. i had a stereo system in the trunk but it didnt really do much except throw more bass in with the music even then it wasnt that much bass. i...
You sold the subs, or sold the infinity kappas? After selling a sub system it is often more than disapointing to go back. It often does sound quiet. You can either deal with it for a couple months until you get used to it, or I'd go with a set of MB Quart to replace your kappas.
Oct 08, 2009 | Infinity KAPPA692.9I Coaxial Car Speaker
I had my subs installed a month ago and a few days ago the subs are working,everythings connected but not working and my subs aren't blown out because i don't have my music that loud so whats the problem?
what model kenwood speakers do you have? what head unit do you have? do you know how they hooked up the rca cables to the back of the deck? if this deck has got 3 pre outs you may have lost the sub pre-out. are you amp lights coming on? if you are still having problems you can take a 9v drill battery or bigger and touch the wires from the speaker to the battery, make sure positive to positive and neg. to neg. the speakers should pop if they are ok, that should re-assure you on the speakers. let me know and ill help where i can. good luck
Feb 27, 2009 | Kenwood Car Audio & Video
Alpine amplifiers fade in and out durring high volume bass hits
main problem i think you are having is your loosing power when it kicks a note.. get a power cap! power caps feed your amps constant power! this will solve your problem :)
Jan 06, 2009 | Alpine MRP-M450 Car Audio Amplifier
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
My subwoofers cut out
You are most likey running too much power from the amp to the speakers.. you might want to try just notching the bass down a notch or 2.. just enough that the bass will hit
Nov 16, 2007 | Car Audio & Video
Cold Blooded Stereo
Switch the input wires from the sub to the speaker amp and vis versa. See if the problem switches to the other amp. If it does, you know you have a fault in the head unit. If it stays in the same amp, then you know you have a problem in the amp unit. Check with the manuufacturer online about how long the warranty is on each unit. Maybe they are still covered. Good Luck Please do not forget to rate this thread.
Nov 26, 2006 | Alpine CDA-9856 CD Player
RCA RS2652 Shelf System Logo
205 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
