Question about Nokia 6233 Cellular Phone
6233 charge problem
I need the charger ways
  • 67 Answers
If your phone does not charge you have to change the base plug also known as charging block,the your phone will result in charging or the present charing block does not make proper electrical connection. advice by dogy
Posted on Jan 04, 2008
3 Suggested Answers
  • 490 Answers
SOURCE: charging problem
problem is with the hardware of the handset so visit nearest nokia care . or visit http://nokia.com to get info about ur handset problem
Posted on Oct 10, 2007
ahlrub
  • 283 Answers
SOURCE: nokia 6233 charging problem
ok... you can dis assemble your fone at u'r own risk...if you have warranty and when you open u'r fone it will be void.. ok here's the basic.. open it.. look for the contacts of the charger and clean it with the thinner on both pin and board and lift the pins a bit... if still the same you cannot fix it by urself.. bring it to the service center...you have capacitors or uem fault...
Posted on Apr 20, 2008
Model # cxr825 desk top charger
https://www.cobra.com/support call their customer service number, I didn't see the chargers for sale individually here, but I would think they'd sell them since they sell the radios.
Feb 20, 2014 | Cobra Radio Communications
Reset bios
No, charger cannot be reset. Your laptop battery probably needs to be replaced or the cells need to be changed.
Best Regards
Oct 24, 2013 | Sony VAIO PCG-3A4L Laptop Charger...
Where can I find a charger for audiovox 2 way radio model FRS100Y
I have a 4 radio wall charger in a motorhome where the radios were missing. It is FRS4WM. I am willing to sell it. Bob
Mar 22, 2013 | Audiovox Radio Communications
Need manual for rival soft serve ice cream maker model 8150
Rival doesn't have the model 8150 listed, but here's the model 8151 manual. Maybe it will be close enough to help.
Aug 07, 2011 | Rival Soft Serve 1.5 Quart Ice Cream Maker
My charger for my Motorola T6510 is not charging. The charger is getting power.
Check your battery contacts, both on the radio and the charger. Clean with a pencil eraser if needed. It is possible you are not getting good contact. If both radios are not getting charged in a dual well charger, you may have a problem with either the wall adapter or the base. (Assuming your batteries are good.) Wall adapters burn out over time, somewhat like a light bulb.
Replacements are available at the Motorola online store. http://www.store.motorola.com/2-Way-Radio-Rechargeable-Battery-Upgrade/dp/B003H0FUD2?ie=UTF8&id=2-Way%20Radio%20Rechargeable%20Battery%20Upgrade&field_availability=-1&field_launch-date=-1y&field_browse=2265964011&searchSize=12&searchPage=1&searchNodeID=2265964011&refinementHistory=brandtextbin%2Csubjectbin%2Ccolor_map%2Cprice%2Csize_name&searchRank=salesrank This kit contains a pair of new batteries and a complete charger.
Best regards.
Nov 04, 2010 | Motorola T6510 XLR Talkabout Two-Way...
My nokia 6233 batteries become useless after charging for sometime
Hello, while your battery behaves that way is because the cell of the battery weak and the battery needs to be replaced.ie, getting a new battery for better performance.
When you get a new battery, everything will work normal again.
Take care.
May 26, 2010 | Nokia 6233 Cellular Phone
I have battry problem with nokia 6233 battary is bp6
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 12, 2010 | Nokia 6233 Cellular Phone
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
I lost the cords to the chargers what size charger am I looking for
u can use any charger as long as plug end is the size or shape as u have on yours. Walmart has about any size u need.
Jul 11, 2009 | Motorola Talkabout T5720 (7 Channels)...
Nokia 6233 Cellular Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
