Nokia N73 Cellular Phone Logo
Anonymous Posted on Oct 14, 2009
I updated my Nokia N73 thru nokia software updater..but since then my main camera i.e on the back side..i can't use it...i slide down the panel camera starts but nothing can be seen....totally black....i cn use by front camera..i.e vga...plz help me out...
Ped078
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Oct 24, 2009
Ped078
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
14909
Points
261
Try the update again in case something went wrong, otherwise it would have to be taken to a phone shop for diagnosis
1helpful
3answers
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
1helpful
I wont to upgrad my mobile software for nokia n73 [email protected]
There are mainly 2 various ways of updating the phone's software. You can do it by typing *#0000# and when the screen pops up, you can go to options then check for updates. Note that if you are using this method you would be charged for data packages by your service provider.
Secondly, you can go to the nokia website and download the nokia software updater(nsu) and follow the instructions given by nokia.
2helpful
2answers
I Dont no how to update my nokia n73me
if u want to update your nokia n73 mobile phone .firstsly download software NOKIA SOFTWARE UPDATER and than install it and connect your any nokia mobile phone and search update for connected nokia mobile.and update your device
MY NOKIA N73 MAIN CAMERA IS NOT WORKING.
Please detail the specific error of the phone. Is the application itself not working or the shortcut buttons are not working(sliding panel, right side button). If it is a software malfunction, try doing the following:
1. factory reset(default code 12345)
2.format card (backup and restore, because sometimes the card gets "broken" virtually)
3.re-install OS
If there are problems with the shortcuts try this:
1. if the side-panel is faulty , try buying a new one
2. if the side button is the one not working, try opening the camera from any other shortcut
N73 phone lock
update your phone without restoring back up.
http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/download
2helpful
Automaticaly closed my nokia n73 memory card application & sheak
kindly update your nokia phone through nokia software updater ..
Software update problem.
first u have to know your mobile code you can find it under the battery its 7digit number
then u enter that number in the nokia site to see if there is a new software for u or no
if u find software then download nokia software updater and follow the steps but be aware of some boints
1-dont turn off your cell or pc becuse this will make your phone dead
2-make sure the new soft support your main languge and if not use the NSS to overright your languge code
and if u dont get it email me and i will be glad to help
my email is [email protected]
Nokia n73 problem
untill unless it will get disconnect before finish its update..it ll affect ur parent board of ur mob...so better check ur main board whether workin or not..after tat ll go for further
111helpful
28answers
Nokia N73 software update problem
during software update N73, the phone does not switch on. what can i do
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
