Question about Polaroid PhotoMax PDC 2150 Digital Camera
Switching on the camera
Dear Sir,
I have PDC 2150 camera. My camera is not switching on after moving its on button towards right direction. What to do. My battery is new. Kindly help me out.
Regards,
Hitesh Bharadwaj
3 Suggested Answers
adib
  • 450 Answers
SOURCE: My new PDC 640 camera is not turning on.
This problem may be due to one of the following: * The lens cover is not open. Slide the lens cover to the right. * The batteries are not inserted properly. Remove the batteries and check the placement of the (+) positive and (-) negative ends. Then reinsert them, making sure they're securely in place. * The batteries are dead. Put in fresh replacements. Power issues may also be the result of using the wrong AC adapter. Use only the recommended AC adapter for the 640.
Posted on Sep 21, 2005
jigsawbill
  • 398 Answers
SOURCE: lost software
I would check out the polaroid web site, you should be able to download from there.
Posted on Aug 05, 2008
What do the letters w and t at top of camera back mean
These mean Wide and Tele, for the zoom. There should be a rocker switch nearby that operates the zoom lens. You don't say what camera it is, so I can't be more specific.
Feb 04, 2011 | Cameras
SDHC card
On my DMC-TZ5 - using the menu button and the surrounding 4 direction buttons.
Put card in camera & switch on.
Press menu button.
Use up/down to select the spanner (wrench) setup menu.
Use right to enter the sub-menu.
Use up/down to find the Format command (the menu will scroll when you move off the bottom).
Use right to select the format command... select yes & the camera does the rest.
May 17, 2009 | Panasonic Lumix DMC-TZ5A Digital Camera
Polaroid pdc 4055
The SD card.has a small notch that is used to lock..usually on the lower right corner of the chip. Move the notch to the other end to unlock the card.
Nov 13, 2008 | Polaroid PhotoMax PDC 4055 Digital Camera
White Outdoor Lawn Tractor 2150
It sound as if there may be a short near the ignition switch.
Aug 25, 2008 | Sport & Outdoor - Others
Lost software
Aug 05, 2008 | Polaroid PhotoMax PDC 2150 Digital Camera
PCD 3030
i have this camera but i need a memory card how much do they cost
May 18, 2008 | Polaroid PhotoMax PDC 3030 Digital Camera
Getting great pictures
Here are some tips for taking great pictures with your PDC 700 camera: * Keep the sun behind you or at your side. Avoid having the sun directly overhead. * Use the Flash On setting if there is a light behind your subject. * In low light conditions, use a tripod to avoid camera movement during exposure. * When possible, take pictures when the temperature is between 13C (55F) and 35C (95F). Temperatures outside this range can affect battery performance. * Keep the subject within the flash range of 18 in. to 10 ft. (0.45m to 3m.) * Avoid shooting toward reflective objects, which can result in "hot spots" in your pictures. If you cannot avoid shooting toward reflective objects, use the Flash On setting . * Periodically clean the lens, the LED area on the front of the camera, and the LCD display on the back of the camera. Use a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
My system locks up when I attempt to download images from my PDC 640 camera.
While it appears that the system is locking up, the actual problem is that a message prompt in the PhotoMAX 2.0 software is hiding beneath other open windows and needs to be answered before proceeding. In this instance, the PDC 640 TWAIN Driver window has been preset to always be the "top" window, obscuring any other windows that may be open behind it. The PhotoMAX 2.0 window must be "active" (or "brought to the top") to answer any message prompts. Once the message prompt is answered, you will be able to download images. To deactivate the PDC 640 TWAIN Driver window's "Always on Top" preset: 1. Launch the PhotoMAX application. 2. Select Get Photo. 3. Select Camera or Scanner. The Acquire From window appears. 4. Select Twain device and click OK. The Select Source window appears. 5. Highlight PDC 640 and click Select. The album window appears next, followed by the PDC 640 TWAIN Driver window. 6. Right-click on the PDC 640 TWAIN Driver window and deselect (i.e. uncheck) "Always on Top". To move the PhotoMAX 2.0 window forward: 1. Launch the PhotoMAX application. 2. Click on Get Photo. 3. Click on From Album. 4. When the album opens, answer YES to the question "The contents of this album have been changed. Do you want to save the changes?". 5. Click on the Acquire icon at the top of the album window to select the PDC 640 camera and download the thumbnails from the camera. Your system will no longer appear to lock up.
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
Polaroid PhotoMax PDC 2150 Digital Camera Logo
27 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
