Question about Xerox Phaser 7700 Laser Printer
Printer fault (phaser 7700)
Fault 4-361
    President:
  • 2,072 Answers
Here is the Diagnostics.
04-361 DRUM MOTOR DRIVE FAIL
EXPLANATION
Poor Drum Motor rotation.
Refer to BSD: CH9.1 CH9.1
Procedure
Remove the Drum ASSY (Y/M/C/K), execute DC330 [004-003].
Does the Drum Motor rotate?
Yes No
Between Drum Motor J210-4 (+) GND (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits up to Drum Motor J210-4. (WN7.3.6 +5VDC-2)
Between Drum Motor J210-6 (+)GND (-)
Is the voltage +24VDC?
Yes No
Using the wire network from Chapter 7, check the +24VDC circuits up to Drum Motor J210-6. (WN7.3.13
+24VDC-3)
Execute DC330 [004-003].
Between Drum Motor J210-1 (+)GND (-)
Is the voltage 0 VDC?
Yes No
Between MCU PWB J407-B1 (+) GND (-)
Yes No
Check for broken wires or bad connections from Drum Motor J210-1 to MCU PWB J407-B1, and if there
are no problems, change the MCU PWB. (PL5.4).
Check for broken wires or bad connections from Drum Motor J210-1 to MCU PWB J407-Bq
Between Drum Motor J210-2 (+) GND (-)
Is the frequency between 1KHz and 1.3KHz?
Yes No
MCU PWB J407-B3 (+) GND (-)
Change Drum Motor. (PL1.1).
Posted on Dec 31, 2007
  • Rick Kasper Dec 31, 2007
    CAUSE:
    Two causes have been identified:
    1. Binding components within individual Imaging Units can produce enough torque resistance to prevent the CMY Imaging Unit Drive Motor from starting
    2. A damaged Imaging Unit Mounting Rail (PL 4.2 Items 6 or 7 in the Phaser 7750 Service Manual) can cause increased gear drag through a misalignment of the diametrical pitch diameters between the drive and driven gears.
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
XEROX PHASER 7700 ERROR 11
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
Oct 26, 2009 | Xerox Phaser 7700 Laser Printer
Fault 37,016.43:9533
You've got some physical problem inside the printer.
See:
http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enca.html
If your printer is networked, it can actually communicate with our support knowledge base directly, and troubleshoot itself.
Sep 10, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox phaser 8200 Won't warmup properly
Does it diaplay a fault code? It may take 20-30 minutes to display. I suspect if you leave it on long enough it will come up with a 15,004.xxx code.
I suspect you have bad drum heaters, but please leave it on for an extended period of time and see what fault code comes up.
Thanks.
Sep 30, 2008 | Xerox Phaser 8200 Laser Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8200N hangs on warmup
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Mar 07, 2008 | Xerox Phaser 8200 Laser Printer
Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7700 Laser Printer Logo
789 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
