Question about Kenmore Dryers
Kenmore dryer runs then shuts off
This weekend we noticed our Kenmore (series 90) electric dryer was had an extreme burning smell and smoke coming from it.  We turned it off and I opened it up later to find the bottom packed full of lint that obviously had been burning.  I took it apart and thoroughly cleaned the entire thing.  Put it all back together and when I push start it spins with a buzzing sound for about 15 seconds, then shuts off and it won't restart immediately. After waiting 30 to 60 seconds their is a little click sound and it will start again, with the same buzzing and shut off pattern.
I called a parts store and they suspected it was the motor, so I picked one up and replaced it and the belt.  Got the dryer all back together and still the same problem.  I can't figure out what the problem is and I'm down $135 for the motor to boot. :-(
I got up close to the under side during one of these cycles and I think the click sound is coming from the heater coil chamber, but I'm not totally sure.
The dryer is a Kenmore 90 Series Dryer (model: 110.60912990)
Any ideas?
  • 2,559 Answers
Motors rarely fail and would not cause your symptoms. You need to check the heating coil for resistance as well as all the associated sensors and wires. There should be a schematic diagram somewhere in the dryer. Make sure unit is unplugged before attempting repairs or diagnosis
Posted on Mar 05, 2017
  • 7 Answers
The parts store should have never sold you the motor. They rarely if ever fail on a dryer. It sounds like a limit switch or sensor wire was damaged by the burning. Check out the wiring and if you feel comfortable jumper out one switch at a time to see which one is not working. Do only one at a time. Photograph everything before you take anything apart.
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Posted on Nov 13, 2008
  • 1122 Answers
SOURCE: My kenmore dryer 90 serise won't start...makes humming sound....
your dryer motor is shot,it is to weak to kick on,sorry-mike
Posted on Jun 03, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
  • 119 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
I have a 90 series washer and I just changed the motor coupler. Now the washer emits a electrical burning smell. what can I do?
not proper fitting has been done so motor is jammed,,,not moved freely so the burning smell is from motor ,,,disamble & assemble properly,,,check brakes fitting also due to jammed motor
Mar 11, 2015 | Kenmore Washing Machines
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 14, 2011 | Kenmore 659 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
We have a Kenmore dryer series 90 model #11066904690 that we started spelling a burny smell. We took off front panel and vacumed out we tryed to use it again and same thing happed and then shut off...
This could be a couple of things. But more than likely the motor has burned out. It could be a wire has burned off, or even the timer has burned. Since you say it "shut off completely", I would have the power cord checked where it connects inside the dryer. UNPLUG it from the wall first! I have seen one wire burn off there from being a loose connection. There is a cover plate you can take off and look inside.
Jul 29, 2009 | Kenmore 659 Electric Dryer
90 series dryer won't stay on
UNplug the dryer, pull it out from the wall, and remove the service panel. Use a flashlight and look around for signs of anything having burned, and smell around to see if you can identify what might be burning if you can not visually see any burning.
If you plug the unit back in while your back there, have someone start the dryer and see if you can see what might be the problem.
I am suspect the motor may be failing, but it's hard to see what's happening through these teeny-tiny little wires.
Reply back what you seeing and we can help you further.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
528 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
