My tv turns on and I can see the picture just fine but there is no sound. I tried testing the volume settings but no luck. Could the speakers have blown out?
COULD BE, THE BEST WAY TO TEST IS, IF THERE IS A PROVISION FOR HEADPHONES THEN PLUG IT, IF YOU CAN HEAR SOUND, THEN ITS YOUR SPEAKERS, IF NO SOUND IN THIS APPLIED STEP.. COULD BE THE AUDIO OUTPUTS, OR FUSABLE RESITORS BLOWN, OR DRY JOITS ON YOUR AUDIO IC..CHECK OUT
hello, my rca p60755at was just returned to me from service. the televisions insert was sent out and...
(More)
hello, my rca p60755at was just returned to me from service. the televisions insert was sent out and returned to me without some of the connections inserted on the main white connection board right behind the middle lamp. is there some kind of way you can help me out or send me the service diagram? please help thanks, kells
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on...
(More)
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on for awhile but now it stays on the odd color. It seems as though the green tint is out
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with...
(More)
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with ours having lines across the screen and the longer it is on the worse it gets. There are only two that run verticle and many that run horizontal. What can we go to fix this?
