FixYa.com
Tags:
GE Side by Side Refrigerator
Ge refrigrater repair (by 3 users)
posted by amit123 on Dec 27, 2007
need some help to fix a ge refrigrater  having a defrost problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by smusa, posted on Jul 13, 2008
My GE stainless steel refrigerator is not automatically turning off. The inside linings of the freezer door gets very hot. The outside of the freezer itself becomes hot as well. I've tried shutting it off for an hour to cool it off, but it becomes hot again within ten minutes.
Comment by umarrerotv, posted on Jul 09, 2008
GE gss22jerfww every two months or less the evaporator is only ice because the defrost is not working the defrost heater is ok 30 ohms more or less the sensor is new same part number (normal close) and the electronic board is new too. my question is do i have to do some setting to the new board because i see that all the jumps are open
Best Solution
posted on Jan 05, 2008
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
you may need a new defrost heater. A part mounted inside the freezer to defrost the coils.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 30, 2007
Not Rated (0)
sagacious
Rank:Guru Guru
Rating: 88%, 126 votes
Chat me
Can you Help with these Refrigerators problems?
GE (PSS26MSRSS) Side by Side Refrigerator
refrigerator no cold
The fresh area no cold and the... Answer This...
water line leading from primary...
how do you disconnect the water... Answer This...
green light flashing on ice...
I read your comment and don't... Answer This...
Replace GE ice dispenser damper...
Need information on how to... Answer This...
Water Line Replacement
My GE side-by-side model ESL25X... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
