Heaters Logo
Problem with Heaters
Troubleshooting Nordyne Furnace. Flashing LED fault condition indicator matches the condition of ''Pressure Switch is Open with Inducer On'' on the wiring diagram. What does this condition mean?
What should I check or do to correct the problem?
Thanks!
Posted by avatar on Oct 14, 2009
Solutions (1)
Your induce fan motor is burnt out or the senor is out. If the little fan is working its just the senor. Your going to need a repairman to find the senor or motor for you. You can replace the senor but I wouldnt recommend replacing the motor. www.fastacservice.com
Add Your Solution
