Computers & Internet Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer aspire 5601 laptop.How to use a memory stick to save a powerpoint presentation entitled malaria in Office 2007
Anonymous
Level 2:
  • Expert 329 Answers
  • Posted on Oct 14, 2009
Anonymous
Expert
Level 2:
Answers
329
Questions
Helped
98879
Points
918
First check for mem card compatibility whether your system support your mem card or not if not then you need to have another mem card reader that support mem card of your card.....do reply back
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
tip
How to recover PowerPoint 2007 password with PowerPoint password recovery...
How can I password protect PowerPoint 2007 Presentation? Many people ask how to add password to the PPT file . Meanwhile, else people ask how to remove or recover PowerPoint password in case they forgot it. Follow these tutorial to get to know how to add password to PowerPoint Presentation, remove PowerPiont password and recover PowerPoint password.
Set a password to open or modify Powerpoint 2007 password
Set a password to open a PowerPoint presentation
  • 1. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document
  • 2. In the Password box, type a password, and then click OK.
  • 3. In the Reenter password box, type the password again, and then click OK.
  • 4. To save the password, save the file.
Set a password to modify a PowerPoint presentation
  • In addition to setting a password to open a PowerPoint presentation, you can set a password to allow others to modify the presentation.
  • 1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  • 2. On the Tools menu, click General Options. The General Options dialog opens.
  • 3. Under File sharing settings for this document, in the Password to modify box, type a password.
  • 4. In the Confirm Password dialog, re-type the password. Click OK.
  • 5. Click Save.
Remove password protection from a PowerPoint presentation
  • Use the password to open the presentation. (Note: If you forgot the Open password, you have to recover PPT password with the third Office password recovery tool)
  • 1. Click the Microsoft Office Button default.aspx?assetid=za100771021033 , point to Prepare, and then click Encrypt Document.
  • 2. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  • 3. Save the presentation.
Recover PowerPoint password with Office password recovery Software
If you have forgot or lost PwerPoint password, the best choice to open the ppt slideshow is to recover PowerPoint password with the third part utility. Office Password Unlocker is a professional Office password recovery tool, which can recover PowerPoint 2007 Password with a few steps.
on Jun 02, 2010 • Computers & Internet
2answers
Convert ms powerpoint 2003 to ms powerpoint 2007
If you have MS Powerpoint 2007 installed on your computer, open the document with MS PowerPoint 2007 and use the save As ... menu.
Click the Yellow Globe at the top left corner of the main window. Select the Save As submenu. On the list of options select Save as PowerPoint Presentation.
Some formatting may be lost but you should be able to save most features.
1helpful
When I try to edit a powerpoint presentation a colleague sends me, bar chart colors change and columns move, etc. I am using Office 2007 with a Vista OS while my colleague is using Office 2003 and XP. I...
Between 2003 and 2007, the default font for MS Office was changed to Calibri. If the file has the font set as <default> rather than specifically set to, say, Arial, 2007 may re-interpret the default font, which can mess up your formatting.
2helpful
2answers
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
1helpful
MS office Powerpoint 2007 presentation
try to find a key for your office if it is genuine you can find key retrival softwares try that and get the key and reinstall it
Acer Aspire One and MS Office 2007 Powerpoint issue
this sounds like a version number problem otherwords check the type face you're using and make sure that one is installed on the other one, MS will sometimes use a compatible font if the font is not found and yes it looks jumbled
Powerpoint 2007
Has the powerpoint document been saved as an office 2007 document or as a prior version? in office 2007 in order to open it in 2003 it must be saved as a prior version of office. You can download a patch to read newer versions, but that is not always the most reliable process.
Format powerpoint 2007 into powerpoint 2003
No prob. Follow these instructions
  1. Simply open the file in your current Office powerpoint program.
  2. Click "File"
  3. Click "Save As"
  4. Just below the name you add is another box called "save as type" Click the triangle on the right and save it as the format you need.
Good Luck!
Grand Canyon Tech
Grand Canyon Tech
