Direct TV HR20 Audio Buzz /humm
Help!!! I have a new Direct TV HD DVR HR20-700 that will start to hum softly then gets louder after a few minutes...Here is the kicker if I change channels, and go back to this channel it clears up for a few minutes, then the problem comes back. seems to be channel dependant??? It will also clear up for a few minutes just by removing the hdmi cable and plugging it back in. other channels don't have the buzzing though.
The cabling is very basic... HDMI from the receiver to the Samsung LCD TV, and a optical cable to the receiver. the buzzing is on both the internal tv speakers and the receiver connected speakers.
  • cheyennemsky Dec 29, 2007
    Direct TV HR20 I am gettng that constant buzz... I tried to reset the Satelite receiver and it stopped the buzz once then it has started again...
  • Anonymous Jan 22, 2009
    I am plugging in my TV via analog audio out on the HR20 box, it sound good for about 20 seconds and then starts buzzing.  Only HDMI output works properly.
  • 59 Answers
SOURCE: DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Posted on Dec 30, 2007
  • 34 Answers
SOURCE: my tivo HD is not broadcasting or recording in HD
I would agree with mjjdesigns. You will likely need to get a cable card, which luckily the Tivo supports to receive the HD signal. Your Tivo may be able to receive the channels without the Card, though I have found that they are often mapped to funny places, for instance on my network, Channel 3 which reports as cable channel 403 with the CableCARD, shows up as 84-3 on the TV and Tivo if not tuing through the CableCARD.
It is possible that you think that you are getting an HD signal through the TV just becuase it is showing up in the 16:9 format. Unless you are tuning to an HD channel (such as 3-1 or 5-1) it is standard definition being stretched to fit your screen. Your Tivo can do this to by pressing the Aspect button on your remote, but it still won't be HD.
Also, if you do get a CableCARD from the cable company, be sure to ask for a multi stream card so that you only need one card and can tune to cable channels on both tuners. Also, I know that the cable companies have often had significant trouble getting CableCARDS to work with the Tivo. Be patient, it is often the Cable Co's fault but they typically pass the buck first to Tivo. Tivo has a hotline established for the sole purpose of working with the Cable Companies to make the cards work in their devices. If you wind up in the situation, call Tivo Customer Service and ask for this hotline.
Hope this helps - Flub
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: Hooked up an optical cable for digital audio
there should be an option to turn this on in the audio settings from the pioneer.
Posted on Jun 29, 2009
  • 56 Answers
SOURCE: I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Posted on Nov 12, 2009
  • 144 Answers
SOURCE: Can I take the access card out of a standard
You can do that but it still won't work. You have to make the changes with Direct TV in person for them to "authorize" your new receiver. More is needed than just the card.
Posted on Jun 23, 2010
How to Access Directv Apps?
DIRECTV TV Apps are FREE and easy to use. Just press the
right arrow button on your remote to launch the TV Apps dock,
select the app you want, and enjoy! TV Apps require a
broadband-connected HD or HD DVR receiver (models H21 and
higher, models HR20 and higher, and models C31 and higher).
Oct 19, 2016 | Televison & Video
Can I take the access card out of a standard Directv satellite receiver and put it in a new Directv HD DVR (HR20-700) without any problems?
Jun 23, 2010 | Directv HR20-700
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Nov 16, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Oct 11, 2007 | Televison & Video
Televison & Video Logo
498 people viewed this question
Top Televison & Video Experts
