Question about RCA DTC210 DirecTV DTV Receiver
RCA DTC210 Directv HD tuner flashes when plugged in
I replaced the above receiver about 5 months ago and did not use for that period of time. I am now going to use that receiver to place in a bedroom. The receiver was working fine when disconnected. Now when I plug in it begins flashing between power and HDTV making a clicking noise. I have not re-activated the card as I was just setting up the receiver on the TV and will call to activate. Is the flashing due to an inactive card? Want to make sure it is not the receiver before I activate as I do not want to buy another receiver. Thanks Scott
  • 3 more comments
  • Anonymous Jan 18, 2008
    never deactivated card, same exact problem
  • jiggy21 Mar 26, 2008
    I have the same receiver doing exactly the same thing (flashing panel lights and clicking relay) . How much tech skill is needed to replace the power supply IC? Do I need to unsolder and resolder a multi-pin chip? I checked Mouser.com and found part# 512-KA1M0565RTU. Is this the same part?--Thanks Doug
    Doug
  • larrickswife Oct 29, 2008
    same thing happened to me. I barely used this thing I put it away safely in a box and went to use it again and I guess it pooed the bed...great lol.
Yeah!!! I did exactly what gmcvoyager said to do and it worked! No more flashing on and off and everything works just fine. Thanks man!
Posted on May 24, 2009
  • gmcvoyager Dec 10, 2013
    You are welcome!
  • 3 Answers
I had 2 units I bought used which were also non-functional, clicking sound (an internal antenna relay) and flashing front panel lights at 2 to 3 times per second, this indicates that the power supply is improperly cycling. After analysis of the switching power supply, I found that the main power device IC had been damaged and was not working properly. When a solid state device of this type fails, it is sudden and final. When replaced, the power supply worked correctly and the DTC210 functions. The part is a Fairchild KA1M0565R power switch integrated circuit which can be easily replaced by a skilled technician. You can look up a data sheet on the internet. While the component was not available at my local electronics parts store, I found it at Mouser Electronics for $3 at www.mouser.com
Posted on Mar 08, 2008
My DTC210 didn't want to work after being stored for awhile. Both lights were ON but there was no output.
I left it turned on and after about 2 hours it started working.
Posted on Jan 21, 2008
  • zuk123 May 30, 2011
    took about 3-4 hours but mine stopped clicking and works normally as an OTA HD reciever
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
Jun 20, 2010 | Sony STRDH810
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
Mar 22, 2009 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
Missing cjannels
sounds as if your dish as slitly gone of line the dish needs resetting
Jan 27, 2008 | RCA DTC210 DirecTV DTV Receiver
Picture goes goofy in 1080i
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power problem
The power supply is bad the voltage is to low on one half to the motherboard forcing it to turn on and off .You need a new power supply.
Oct 19, 2007 | RCA DTC210 DirecTV DTV Receiver
Where can i buy this product´s tuner component
See details in: http://www.rca.com/product/viewdetail/0,2588,PI700057,00.html?
Jan 17, 2006 | RCA DRD430RG DirecTV DTV Receiver
Televison & Video Logo
532 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
