Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
Problem for Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural...
Replaced pcb need getting code
By heinzsj on Oct 14, 2009
replaced pcb need getting code -0 82, imagine i need to configure for gas type but dont know how
Comments:
Oct 14, 2009
- thanks for the thouhgts ... this is a new board as a function of the c7 76 error code indicating bad control board or connectivity between remote control and control board. I've cut the remote control wires and both ends, re-stripped and reconnected with no change in error conditions. Installed a new control board and reattached remote control and received error -0 82, which I've been led to believe means that the new control board needs a bit of configuration for either altitude or gas type; e.g., natural or LP. I apte the help, but it didn't help solve the problem.
Solution #1
posted on Oct 14, 2009
Not Rated)
charlymonty
Rank: Wiz
Rating: 82%, 243 votes
you can call rheem customer service at 18004328373 you will need model and serial # before they will help you .the actual problem by what the error code is showing on the display is as follows: the main circuit board is not proving power to the thermostat so its showing this error.the main control board needs replacement.but many times it gets reset by doing this as follows:-- disconnect the thermostat/digital display from the main unit. This is fairly simple to do by removing the front panel.then again reconnect after some time and check out. --------- This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Solution #2
posted on Oct 15, 2009
Not Rated)
muebe
Rank: Guru
Rating: 91%, 312 votes
I have seen your problem and I do not know if I can help but thought I would give you some ideas. Now I know you are aware the error is for wrong gas type. Are there any jumpers or tiny switches on the PCB that would allow for adjustments to the gas type? Also I would check the actual thermostat...There might be a switch inside the thermostat unit that can be adjusted. And make sure that the PCB that you installed is not for LP gas and creating an error. I don't know if you have already been given these ideas.
Popular Solutions for Rheem RTG-74PVN-2 Natural Gas
Questions and Unsolved Problems for Rheem RTG-74PVN-2 Natural Gas
Do you recommend Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat?
Answer
Answer
Recently purchased new home, pilot light on the boiler was not lit and we had hot water pretty much... (More)
Answer
after installing the water heater we opened the hot water and after the air came out and everyting,... (More)
Answer
Hi, I have a new Sime Ecomfort 25 HE wall hanging boiler which is dripping small amount of water... (More)
Answer
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before... (More)
Answer
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Water Heater Experts
Top Heater Repairmen
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
