Question about Sony STR-DG600 Receiver
Remote not working
My remote stopped functioning. It works on the tv (also Sony) but not the receiver. I unplugged, changed the batteries, deleted all programing and no result. I would appreciate any help.
  • 3 more comments
  • babangida Dec 27, 2007
    Where do I find another IR transmitter?
    Tx, I'll try that.
    After I opened it, it started working.
    I opened the remote
    Will do.
    Tx
    Edi G.
    Guru:
  • 1,894 Answers
If u know how to open the remote please change the IR transmitter in front of your remote.
a small light like bulb in front of the remote
Posted on Dec 27, 2007
  • 7 more comments
  • dewan nafees ahmed Dec 27, 2007
    you can find at all small shops selling electronic goods like resistors, capacitors etc etc.....
    even if u take it to them they will do for u in just few minutes.. its not a big deal..
    if this changing of IR transmitter is not working there is some problem in the circuit.
    in that case you can go for a new remote or an equivalent remote like that
    IR transmitter will cost very cheap. dont worry..
    hey stop...
    dont change the IR transmitter in remote. the IR reciever of the reciever.. not the one of your remote
    please dont change the IR transmitter of your remote. the IR reciever of your reciever must be the exact problem. u can even get that also in the same shops.
    if u dont know to open it take it to them. they will do it for u at a very less charge... sorry for giving wrong solution previously.. i misread your problem.. sorry
    cool. problem has solved is it?
    actually what you opened? the remote or the reciever.
    then now close it and use.. i think it will work normally.. if not means tel me..
    ya do it.. and then tell if problem was solved or not
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
My remote control simply stopped working altogether. I changed batteries 3 times(and verified the batteries were good). The dvd/vcr controls on the player itself function properly. I cleaned the remote...
If it is a universal remote not branded to the tv and the batteries went dead or are out for too long then the remote lost the codes and needs to be reprogramed!
Mar 15, 2010 | Sony RMTV501A Remote Control
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Apr 11, 2009 | Toshiba 36AF42 36" TV
Remote works intermittently
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Oct 09, 2008 | Kenwood VR-407 Receiver
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony STR-DG600 Receiver Logo
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
