Question about Sony PlayStation 2 Slimline Console
Did I fry it?
Just bought a 7000 Series PS2 on saturday and mixed up its power cable with my laptop's today. My laptop uses 18-20 volts and the PS2 uses 8.5. Now the disc won't spin and the laser won't move. Did I fry it beyond repair? What's a repair like that cost?
There wasn't any popping or smoke or anything when my wife plugged in the wrong cord and turned it on. It would read the memory cards with the wrong plug in, but like I said - discs won't spin and laser won't move. Switching back to the correct power cord didn't help either.
    New Friend:
  • 127 Answers
Hi hamstermann,
Fried like bacon is about all I can say.
Thats alot of volts going through something like that.
Not sure what a 7000 series costs,
but hopefully you have warrenty to cover it.
Just between you and me, dont tell them you messed up the cord.
Posted on Dec 29, 2007
I bought an Acer netbook last week. Love it. Today, I am in Germany and it will not charge. I have an adaptor, but the charge light on the netbook does not come on at all. It boots up fine from the...
Most power adapters are able to run the Euro 220v @50/60hz but make sure. The "Input" side should say 110-240V and 50/60hz if it says only 110v and 60hz then you power supply will not work in Germany. Also check to see if the "output" on your power cord is the same as what is your laptop is. I have mixed up power adapters before and it will simply not work. If you try and plug it in it will fry it. If you have to grab a new power adapter the best store i can think of is a place called Saturn Electronik kinda like Germany's Best Buy. It has a hazard orange sign most times.
May 09, 2011 | Acer (56.04145.901) (5604145901) Power...
My motherboard takes this: 1 x 8-pin ATX 12V power connector. My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
Better than Amazon.com Andrew,
http://www.directron.com/ad202.html
Converts two 4-pin standard Peripheral power cables, (Molex) to one female 8-pin EPS +12 Volt power cable.
4-pin Peripheral +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ NOTE*
Designated a 4-pin Standard Peripheral power cable, because there is a 4-pin Small peripheral power cable ]
A) 8-pin EPS +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
B) Note the difference from an 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
{4-pin Small peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Used on the older Floppy Drives, and also used on today's Card Readers in desktop computers }
Apr 16, 2011 | HP Computers & Internet
Ps2 110 volts and i plug it in 220 volts
hi if your saying you have got an american or other ps2 that runs off 110v and you have plugged it into a 220 volt mains supply then the chances are the ps2 is now fried, if it was like an xbox and had a power pack then it would only be the power pack at fault, how ever as the ps2 plugs direct to the mains then the chance of getting this working is pretty slim unless you replaced most parts on the circuit board, what i would do is sell it as faulty and buy another one as it would cost more to get this fixed than it would to get it replaced.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 06, 2010 | Sony PlayStation 2 (PS2) Console
Disc won't turn on PlayStation2 7000 series
if you look through the forums you will notice alot of people are having the same problem. The laser on the ps2 gives out usually b4 anything else. however, try a cleaning disc and of course a different game before discarding the system. Replacing the laser would cost more than a new system. you could get a used ps2 for 25-50 bucks used from a pawn shop but make sure they test it first.
Apr 18, 2010 | Sony PlayStation 2 (PS2) Console
No power, no lights on laptop
I think you should check the real power supply ... 120 V in and what comes out ... volts (ac - dc) and amps or what fraction of an amp.
Please compare the old with the new power supply. The new power supply should be the same volts - same kind (AC or DC) and at least the same amp rating. You can use higher amp rating but not lower - lower will burn up - literally)
Volt meter ... always set it above the suspected voltage. Batteries are always DC. Houses, buildings, etc always AC. Power supplies - could be mixed - ac in and dc out.
So if you were measuring in your home, you set the meter to 130 or higher on the AC scale. If you were doing your auto, 24 volts DC (or so).
House current, probe color doesnt make any difference. Should read about 120 Volts between the narrower (or right side/ground down orientation) or the two slots and the wider of the two shots (wide should be the neutral side - ground on the bottom). You can prove the hot side by measuring to the ground. White wire to ground = no reading. Black wire to ground = 120 volts. (The black and white are INSIDE the electric outlet. You can use either probe to do the measurement.
I hope this helps you.
If you have more question, please let me know.
Thanks for using fixya.com
a
Oct 23, 2009 | E-Machines M5309 Notebook
My slim playstation 2 is not working need answer quick
Haha i understand your distress :) if your slim ps2 is not turning on, first check and make sure that all your wires and stuff are all plugged in to EVERYTHING. also, make sure your outlet works too. corroded electrical outlets wont work. Also, make sure your PS2 cooler is not blocked in any sort of way. if you need any more issues, just ask :) ~~RJ~~
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
Titan 7000 generator...the generator is not
you know , i have helped several people on thire cars , i want a fix and you want money...not faiir at all....i thought this sight was a helpful sight...i see diferently now....thanks
Sep 02, 2009 | Electrical Supplies
Ps2 parental reset code
As long as you have a PS2 Slim model 7000 series then we can fix it for you. We would charge only $20.00 and can provide directions via email. We accept Paypal, check, money order, and wire transfer.
Please email if you're interested - sbl.games@gmail.com
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
PS2 bought in the US
hi if your using original disk then you dont have to worry, regarding power its common that 240 volts devices has a autovolt feature you should try to take a look at the back of the console and if your ps2 is 120v or 110 you should use a transformer if your putting it to 220v outlets because if you dont your ps2 will be ruined, thankyou and have a nice day and Godbless you
Dec 09, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
