This recently started happening but when I plug in the charger into my computer it immediately shuts down and wont turn back on until I take it out. Whats wrong with my computer?
Sounds like you have a battery problem.
Try removing the battery and starting the unit.
After the unit starts up and has settled into a normal idle screen, flip the unit over and snap the battery back in.
If the unit does not run without battery installed, or if you notice any screen flickering, you may have a bad charger. This unit should still be within warranty.
You should contact customer care via email and log your problems, a case manager will pick up on the problems and should repair at no charge to you.
your laptop is hard wired to shut down when the input is to high into this port. You more than like have a damaged AC/DC converter box in the line (the little box on in the middle of the power cord). This handy little thing converts your powerful and destructive AC current to a DC range that is compatible with the delicate circuits of your system. I would recommend refraining from plugging this system in until the cable has been replaced as you may soon encounter catastrophic failure of key components. HERE is a link to heck out a few online purchase options.
GOOD LUCK AND PLEASE RATE THIS POST!!!!!! :D
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for HP HP Pavilion dv7-1130us 17"
hi my laptop is acer aspire 5738g with windows 7 .its new the first time i turn it on the power...
(More)
hi my laptop is acer aspire 5738g with windows 7 .its new the first time i turn it on the power button turn blue the fan start but the screen is black the hdd is not flashing so i force it to shut down by hold power button for 5 seconds then start it again and its on without eny shortage so i turn it on and off several times to make sure its ok and there was nothing wrong and it was fine . but after a 1 houre of shut down the same broplem come again i tried to ubdate the bios and it works for one day without this broplem but in the second day it came back , i think its bios or not please help ... acer aspire 5738g 2.2 core 2 due 500hdd 4gb of ram windows 7
i have a 1510 but i cant see any bluetooth option on every window and option . is this model have...
(More)
i have a 1510 but i cant see any bluetooth option on every window and option . is this model have internal blootooth? where & how can i active it?
I cannot open my optical drive manually. It's seems to be stuck... but there is no light indicator...
(More)
I cannot open my optical drive manually. It's seems to be stuck... but there is no light indicator to identify... I have a MSI megabook S430 series
