Question about Freezers
Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
My freezer alarm goes off eventhough the temperature is registering about -20F. I have tried adjusting the thermostat to the lowest possible setting but the temp holds around -20F and the alarm still goes off. Can someone help me out?
  • 2 more comments
  • andonis Dec 27, 2007
    Do you have any recommendations on how to change? Is this something I can do myself?
  • andonis Dec 30, 2007
    AFFC2528 is the model number. One interesting thing I noticed is that if I turn off the freezer until the temp goes up to about -5F and then turn it on, the alarm does not go off, until the temp goes below -15F....don't know if that makes the diagnosis different.
  • Anonymous Mar 08, 2008
    alarm goes off twice daily but temperature is below 0
  • goonerfu Sep 26, 2008
    the alarm is going off and the food is still frozen. what is going on...
  • 447 Answers
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Posted on Dec 27, 2007
  • joey  shearer
    joey shearer Dec 27, 2007
    ill need the model # for more assistance
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
We have a Frigidaire Model FFC25C8CWO 25cf commercial freezer chest. The alarm keeps going off. The temp is below zero and we can't get it to get warmer. What can I do? Is it to cold is this why the
Hello Judy, thanks for your post!
From my understanding the alarm on your Frigidaire commercial chest freezer continues to go off. You have explained that the temperature is at zero degrees. It sounds like you could have a potential issue with your thermostat or sensor. I would recommend having a professional technician come out to properly diagnosis your freezer to avoid any unnecessary part purchases. Good luck. -Matt
Dec 14, 2014 | Frigidaire Freezers
The alarm keep going on with no reason on my frigidaire ultrafreeze
Hi michael, thank you for your post!
I understand that you are having a challenge with your Frigidaire freezer's alarm continuously going off. From what you are describing it could be a possible problem with your control panel or sensor. Typically the alarm will go off when the freezer senses a high temperature inside, I would recommend having a professional come out to properly diagnosis your appliance and repair it to avoid any unnecessary part purchases. -Matt
Oct 13, 2014 | Frigidaire Freezer ULTRAFREEZE 13.8 Cu....
My chest frigidaire freezer starts beeping about an hour after I plug it in and I can't get it to stop what do I do
Does the freezer get cold? To what temperature? Is the lid closed tight? What do you have the temperature set at? Is it set to zero or below? Is it an automatic defrost freezer? If so, have you set the auto defrost to off? If you turn thee temperature all the way to the lowest setting, does the beeping stop after awhile? Usually beeping means a lid/door ajar or a temperature problem.
Jul 13, 2014 | Freezers
Ambient temperature
This is true of all HVAC type systems. The condensor releases heat from the expansion of the coolant. As long as the temperature is lower than the exchanged heat then there is no impact to efficiency.
Mar 07, 2014 | Woods Freezers
What is the coldest recommended temperature a chest freezer can withstand in an unheated garage?
Hi there
It should have no problems down to -30 deg C or -20f
But it may sweat on the outside if it is damp and cold, which can cause corrosion of the casing.
Below the above temperatures the thermostat will not operate
Regards
Gordon
Apr 17, 2011 | Freezers
Frigidaire freezer CHEST FC263C USER manual. a red light is showing
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297079200en.pdf
Page 5 explains that the "Red" light is lit until temperature is reached.
Mar 06, 2011 | Frigidaire FFN15M5H Chest Freezer
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
Chest freezer not freezing
home refrigeration units are not designed to work in low temperature areas. where temps will drop below 45f so that is your problem. this is listed in your owners manual if you want to verify. thx peyton
Jan 30, 2009 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezers Logo
959 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
