Old computer i format the hard drive i can't get the cd rom to run the program what do i  need a floppy disk to make my cd rom run my program?
    Sergeant:
    Champion:
  • 243 Answers
What operating system are you trying to install? Is the pc set to boot from the cdrom 1st before the hard drive?
Posted on Dec 29, 2007
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
How to format acer one laptop without cd-rom?
Use an external CD rom or sometimes there is a petition file in the Hard drive to format.
Oct 19, 2010 | Acer Aspire One PC Notebook
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
Stepbystep procedure for formating
Hello jerapur_123 What you'll need:
  • Recovery CD or Restore CD from the MFG
  • WIndows Operating Disk 98 or ME, 2000, XP or Vista.
  • A CD Rom Drive
  • Or a Floppy for low level formatting.
Key Steps to Formatting
Back it Up!
Before the format process, you want to make sure that if your goal is hard drive recovery, you back-up as much personal data and information from your hard drive as you need. In some instances where a virus has caused serious system damage, this may not be possible, but if your format is planned ahead of time you certainly can copy and archive data off your hard drive before you start the format process.
How to Format
If you purchased your computer from systems vendor such as a Dell, HP Compaq or Gateway system, you most likely will have a set-up or a restore-and-recovery CD (also referred to as a master CD) that came with the system. If this is the type of system you use, then a format is an easy process as the master CD by inserting the CD into your CDROM, will format the hard drive, reinstall your Windows operating system, and install any software and programs that came with the system. If you no longer have your master set-up CD, you should contact the manufacturer to get a replacement.
How to Format without a Recovery Disk:
If you aren't using this type of mass-market system, then a hard drive format will consist of you formatting the hard drive manually, installing your Windows OS from CD, then installing your software programs and hardware drivers. Before you begin the formatting process, it is important to make sure you have all your driver CDs located, Windows CD and your software CDs to ensure a smooth set-up.
It's also important to know about your operating system before you format. For example, if you're going to be reinstalling an older version of the operating such as Windows 98 or Windows ME then you should have a Windows 98 or ME start-up disk to complete the procedure. In this instance, you would restart the system with the start-up floppy in the drive. Upon system boot, you will choose to have CD-ROM support. Once the files load you can then choose to run the format command on your main drive (usually C drive). If you are using Windows 2000, Windows XP or Windows Vista the Windows installation process offers "format your hard drive" as an option. Here you would ensure your computer is set to boot from CD-ROM (a setting in your system BIOS), insert the Windows CD and restart the computer. From there you will be on your way to reformatting.
As you can see there are many options to formatting a hard drive. Hopefully this gives you a good understanding that most of the operating systems today do the formatting for you, all you need to do is pick that option as you follow the onscreen steps when you install either your Restore, or Operating System.
Good Luck,
Mark
Please don't forget to leave a rating.
Feb 18, 2009 | HP Computers & Internet
Disk with data stored on it says that it is not formatted
Maybe you had something with a magnetic field lying nex to the flopy drive and the code got mixed up and now the data is not readable.
You can try with raw extraction like in CD's. you need to have a program to recover the data without having to actually decode them. I used to use Recovery Toolbox for CD's, I'm sure there's a simular programe for floppy's somewhere on the net. after recovering, things worked on the computer, although the dish was never usable since the day I got the message 'can't read data'/'no data'/'not formatted' etc.
With floppy's I think that you'll never get the data from it by computer itself. I didn't get the data from the corrupt CD's, and they have much more advancer programs than floppy discs. so I recomend you find the program, get the data and throw the floppy away. If you have problems finding the program, post and I'll help.
Feb 02, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
Floppy disc not working
Sometimes u can go to a different computer and get the disk to work. Most of the time u can't though. I suggest you try a few different computers (new and old computers) and if you get one to read it get your info off and save it to another floppy or a flash drive or something. I have also tried the format option and it will always say that the disk can't be formatted. I usually toss them in the trash after that.
You may also try running a standard windows scandisk on the disk. A lot of people feel more secure saving their stuff to a floppy, mostly because it's something physical they can hang onto and carry around. But the truth is that they are far too unreliable to use given the wide range of other options available today (e-mail, ftp, jump drives, hard drives, cd-roms, etc.)
Jan 20, 2009 | Sony (1QTY) Beige 3.5" Internal Floppy...
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
Format the partition by using the NTFS file system (Quick)
Format the partition by using the FAT file system (Quick)
Leave the current file system intact (no changes)
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base:
Oct 19, 2008 | Computers & Internet
Old 95 computer
well you have to get the cd you may have to buy it or get that from somebody
Dec 27, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
301 people viewed this question
Alun Cox
David Payne
David Payne
