Question about Nokia N70 Cellular Phone
My N70 IS NOT SWITCHING ON.
IT FELL from my bed on the floor, when i gave it for service,they said the circuit board has shorted and cant be repaired...ny1 plz giv a valuabl solution!
    President:
  • 1,017 Answers
I suppose you've tried removing the battery and re-installing it!
and the sim card.
But if it has short circuited then its a burial case.
Posted on Dec 27, 2007
Tv fell off the stand onto a carpet floor now wont turn on
Possible that the fall has damaged the mother board and so there can be CRACK ON THE MOTHER BOARD. So you need to remove power cord and check using a good inspection lamp on the board for broken circuit board. Use a good soldering iron with wire strips to join - take care not to short circuits as each line must be tested for short and continuity.
Jul 27, 2011 | Philips 32PFL3505D 32 in LCD TV
My external hard drive fell off my bed onto the floor. Now it is no longer recognized by my computer. How can I retrieve the data that is currently on the hard drive.
Well this could be a tough one.
It seems likely that how much experience you have working with hardware as well as how willing you are to work with computer hardware my be a big factor.
Anyway. At this point does the external drive show ANY signs of life? Does it's led come on?
Does the drive seem to come to life? In other words. Can you heard the drive spin up (or spin in general for that matter)?
Also does the drive make any loud clicking sounds? Does the drive make any sounds that it was not making before it fell off the bed and on to the floor? Or is it failing to make any sounds that it always made before it fell off the bed?
Here are a few suggestions:
First consider carefully how valuable the data you wish to retrieve really is to you as opposed to how valuable the drive itself may be to you. For example, is this drive still under warranty?
If you open up the box it will void the warranty. If it is still under warranty they will probably replace it. So this is a serious consideration.
If the drive is no longer under warranty then it is not an issue.
If your drive shows NO signs of life then it is not getting power for some reason. This could be anything from a broken or disconnected wire inside the box to a broken interface printed circuit board.
If the led lights up but the hard drive does not spin up then this could also be anything from a broken or disconnected cable inside the box to a broken interface printed circuit board. It could also be that the drive has suffered catastrophic damage. If it is the later your data is history.
If the drive is making any loud sounds it never made before it is also highly likely that your data is history.
You can open the box your self and check for problems like disconnected or broken cables. Which should be easy to fix.
In any event good luck...
Jun 12, 2011 | Western Digital WD My Book Essential 1TB,...
My nokia n70 when charging, the battery expanded and damage the battery. when i send it to the shop, the technician informed me that the defect is on the motherboard and told me that it cant be repaired...
its true , there is the problem relating with the main Board short circuit it consumes more battery power and leads to the expansion and damage to the battery . A good technician can repaired it . this is a common problem faced by the n70 users
Oct 13, 2010 | Nokia N70 Cellular Phone
My Tv doesn't power on!
hello the glass fuse inside the tv might have come out or worse the circuit board might have broken
shaun
Apr 08, 2009 | RCA R52WH73 Projection Television
Fell in the floor and into the water
These kind of problem cannot be solved unless the phone is examined. Some part of the board might be short circuited due to the entry of water. You will have to give the phone to the authorised service center to get the stuff repaired. Thank you!
Mar 10, 2009 | Cell Phones
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
My main camera doesn't work for nokia n70
Hai,
After the fall, ur phone camera which is slightly heavier component might have got some kind of shock.
Please try to visit a service centre for its service. It should'nt cost that much.
good luck
Rabby
Jun 16, 2008 | Nokia N70 Cellular Phone
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Jan 03, 2008 | Acer Aspire 3680 Laptop
Nokia N70 Cellular Phone Logo
69 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
