Question about GPS
Garmin satellite issues
I have a new garmin nuvi 200. Used it today and when I put it in the window mount it would not acquire a satellite- for over 1/2 hour. Then it would get it for a minute and drop it. In frustration I took it down and set in the passenger's seat- poof, it started working and worked fine. When I put it back in the window mount it lost the signal again and again. Any thoughts?
  • Anonymous Dec 31, 2007
    New Garmin Nuvi 200 for Christmas. It can't locate satellite anymore--no matter where it is in the car. Help!
I actually resolved my problem- I returned it after Garmin had me try several things and it still didn't work. Said it was a defective unit. New unit works great. Couple of things I would suggest is to reset the unit- by pushing reset on bottom of unit (you will not lose all of your data). If that doesn't work, do a complete system reset (you will lose any stored data). While pushing the reset button, hold your finger on the right corner of the touch screen (with unit turned off). This was the last thing Garmin had me do before we gave up! Also, when you fired your unit up for the first time you were outside so it could get good satellite feed on the initial start-up? Apparently that can make a big difference.
Posted on Jan 02, 2008
I have the same problem. I took it back and got a replacement. But it also has the same problem! So frustrating.
Several makes of cars most notably the Saturn have coatings on the windshields that block some frequencies of RF, for example the RF that is used to communicate with the transponder on automatic toll collection on Toronto, Canadas' Toll Rte. Hwy 407. Perhaps that is the issue as your unit aquires the satellite when placed near a different window.
Posted on Dec 29, 2007
My Garmin Nuvi 3790T will not acquire a satellite signal
Does the GPS work outside of the vehicle?
Where is the GPS mounted?
If the GPS is under the dash, mounting it up on top of the dash will help.
If the Vauxhall has a windshield with a reflective metallic coating or treatment in the glass, this may result in poor GPS satellite reception.
Apr 12, 2012 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
My garmin 255w keeps telling me that it's
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Aug 17, 2011 | Garmin nuvi 255W GPS Receiver
The touch screenon my Garmin Nuvi 600/650 won't work. What can i do?
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jan 21, 2010 | Garmin Nuvi 660 GPS Receiver
SLow to acquire satellites after being turned on in the car
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Dec 07, 2009 | Garmin nuvi 200W GPS Receiver
Ive been getting the message ''acquiring satellites'' since yesterday morning
I hope that helps.
___________________
Dec 02, 2009 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200, less than 2 yrs old. Has probkems acquiring satelite. Has GPS sw 2.50b and audio 2.20. Also, where and how much is usb adaptor that fits to left side of unit (special plug in to unit
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W.
The usb cable you require is a standard USB to mini-USB cable. MP3 or camera cables will work.
I hope that helps.
___________________
Oct 14, 2009 | Garmin nuvi 255W GPS Receiver
Frequently loses satellites.
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor satellite reception, loosing satellites, and taking a long time to acquire satellites are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Sep 20, 2009 | Garmin n?vi 265WT Car GPS Receiver
Acquiring Satellites
Does it do this outside of the car too?
Have you resetted the device? (bottom of the Nuvi)
Jun 23, 2008 | Garmin nuvi 250W GPS Receiver
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
504 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
