Question about Dishwashers
Maytag Jetclean Dishwasher Model #WU284
This is an older Jetclean that was here when we bought the house. I cannot find a manual and need to know if there is a drying agent dispenser that I just can't find???
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: Kenmore Elite dishwasher model 665.13793K600 not working
Couple of things you might check. Make sure that the soap dispenser is clean and not gummed up. What kind of cleanser are you using? If you are using the packets that melt upon contact with water, you might check to see if the wraping is sticking to the door. If the washer is loaded in such a way as to prevent a quality size stream of water to get to the dispenser it just may stick. This was happening to mine. I like to make sure the dispenser is dry, and the front of the racks by the dispenser are clear of any large article that would block the stream of water. Also, once I put the detergent in I start the machine. I do not let the detergent packet partially dissolve and then dry onto the dispenser thus preventing it from opening properly.
Posted on Aug 06, 2009
  • 228 Answers
SOURCE: I accidently put Jet Dry DISHWASHER CLEANER in my
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Posted on Feb 17, 2010
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
Hope this helps, and good luck!
Nov 19, 2015 | Maytag Dishwashers
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
Need a diagram of how to put the lower spray arm witha tower back into the bottom of dishwasher Maytag model WU284
I think you are looking at item 1 in this diagram.
Hope it helps. Please rate the solution if helpful otherwise post a comment.
Nov 16, 2010 | Maytag Dishwashers
I just need an operating manual for a Maytag Quiet Series100 Dishwasher, Model No. MDB5600AWW.
Nov 09, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag jetclean dishwasher is not cleaning the dishes and the soap is not dispensing. I am also not sure the water is coming in? Help?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Jun 10, 2009 | Maytag MDB9600A Jetclean II Built-in...
How to install?
Look carefully at the model number of your dishwasher and type it in here:
May 08, 2009 | Maytag MDB9600A Jetclean II Built-in...
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
547 people viewed this question
Top Dishwashers Experts
