Question about Dayton E50 Heater
My E 50 Dayton heater
My heater has fuel air and spark it fires up and shuts off right away
  • 1 more comment
  • 03mustang Dec 27, 2007
    any other suggestions would be extremely helpful. thanks for any help its a little to keep working on my car BURRRRRR
  • 03mustang Jan 03, 2008
    thanks I will keep looking
  • Anonymous Mar 08, 2008
    Heater starts and run for about two min. then shuts off you can restart it and it dose the same thing.
  • 25 Answers
It could be a power connection problem or possibly a safety shutoff
Posted on Dec 27, 2007
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
Have a 120000 btu fuel fired torpedo heater that fan spins and fuel drips but no spark
fuel is atomized by the blower fan, and a sparkplug provides the ignition source. this sparkplug provides constant ignition spark for the process.
Jan 03, 2010 | Dayton Heating & Cooling
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Dayton kero heater wont fire0
OHH I bet this is the same question I just posted to. So it is a forced air kerosene. The usual is like I said a blocked combustion air hole. It could also be something shorting out the spark ignition to ground when replaces inspect the wires and look for a week or loose ground in this case. Sorry about the confusion.
A Bad ignition proving circuit or something like (what we call here dirt dobbers) hornets nest could be letting the flame hit it and not allowing full flow through the heater. Mice are also notorious for making problems like wires chewed and nests in the wrong place. Given where it may have been stored.
Jan 15, 2009 | Dayton Electric Heater
Dayton 175k heater
the air pressure is not correct on either units.the photo cell DOES NOT look for light any more,it count the light flashes.if the flame is not in the right possition the heater will shut down....after the unit ignites the ignitor is no longer used to keep the unit working,just the fuel that is being fed to the flame ball.that's why the pressure is so inportant.......
Jul 08, 2008 | Dayton E51 Oil Filled Utility Heater
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Dayton E50 Heater Logo
175 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
