Question about RCA F36668 36" TV
Can't get some channels anymore
I was able to get several channels but now I can't get any channels above channel 13. Help please.
MIchelle
    Genius:
  • 1,153 Answers
You need to turn antenna off and put to cable in menu
Posted on Dec 27, 2007
Philips tv want go past channel 13
This usually means channels above 13 are not programmed with a frequency and so are disabled. A re-tune might help.
Oct 12, 2014 | Philips Televison & Video
I cannot type in the channels on the remote anymore? I can scroll the channels??But I canot type in channel number. For example channel # 25 there is only 2 lines and it goes automatically to channel 15??...
your remote maybe dirty inside where the semi conductors are that designate what numbers you are ppushing. you can take it apart and clean it under the rubber. if that dont work get a new remote
Jan 30, 2011 | Samsung CXJ1364 13 in. TV/VCR Combo
We cannot get the tv to go to channel #3. It will only go from aux - channel 2. We don't have a working remote anymore. help
You can buy a brand new remote control here:
http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=N0162UD
Jul 04, 2010 | Emerson EWC1303 13 in. TV/VCR Combo
I can't program channels above 13
Check your TV settings and be sure to set the tuning mode to cable (sometimes it says CATV). You will find it's set to "air" now. When set for off-the-air tuning, cable channels 2 through 13 work fine, but above that you get nothing. After you set your tuning mode to cable, rescan channels and ou should have everything.
Apr 01, 2009 | Toshiba CF20F40 TV
In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Mar 20, 2009 | Zenith Z32X31D 32" TV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
RCA F36668 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
