Question about Proscan 19LA25Q 19 in. LCD Television
No sound from speakers
How or what menu do you go to to turn internal speakers back on for this model?
    Problem Solver:
  • 12 Answers
This might help you.
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Posted on Apr 04, 2008
How do I turn of the tv speakers on this model?
There should be option to stop the output from its internal speaker/s; provided there is "audio out" socket/s at the back of the TV. If there is no "Audio Out" sockets at the TV; this option will not be there at its audio menu.
Electro help
Dec 01, 2014 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
My rca hdtv model hd52w67 has picture but no sound
The model indicated rarely has sound problems.
General things to check:
If using a cable or sat box is sound muted or turned way down?
In set menu are speakers on or off?
Some versions have a slide switch either on the back or in the menu for internal or external speakers.
Does the set have sound with a DVD etc hooked to a rear input?
If no sound only on a few channels SAP may be on either in the set or a box.
If none of these help it has a audio circuit problem.
Mar 28, 2012 | RCA HD52W59 HDTV Projection Television
How do you turn on the internal speakers for a toshiba regza 55 inch tv
some of these sets do not have internal speakers. If they have red and black connectors on the back marked speaker out it has external speakers. that being said, if yours has internal speakers go to the set up menu and fallow down to audio. IT will be found there. SPEAKERS ON /OFF
Feb 20, 2011 | Televison & Video
No sound coming out of my Mitsubishi Model CS-2013R (older model). Picture is still great. Just no sound all of a sudden. TV nor DVD player (running through it) project sound...
The older TV's have a switch in the back what if bumped will cut the speakers off. It is for internal/external speakers. Check the switch & make sure it is set for internal speakers. If that still does not solve it, go to your Menu screen advanced options and make sure the speakers are turned on. If it is and still not audio, then you may have a problem with the internal amp or the audio switcher. Note you will need the factory remote for the advanced options
Nov 08, 2009 | Televison & Video
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
No sound from tV speakers
check your speaker, use a battery 1.5vdc tap it to speaker wire if the speaker is ok you can hear a click sound as the wire touches the battery + & - .
Sep 10, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Turn the speakers to ON
No I am not using a hdmi input. This problem exists within the unit itself. I am unable to manually turn on the Televisions internal speakers. they are currently set to off and are not highlighted within the menu to be able to turn them back on. I hope this helps. thank you!
Nov 17, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Sony KV-27FV16 no sound
Try going into the audio settings part in your menu and select reset audio settings.
May 16, 2008 | Sony KV-27FV16 TV
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Proscan 19LA25Q 19 in. LCD Television Logo
154 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
