Question about RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence problem
Colors are way off and the pictue is bowed. The is no "auto convergence" on the menu at all. Tha seems wierd since the manual shows one. Is there a fuse or something that can be checked inside this unit? Any assistance would be helpfull.
  • 1 more comment
  • jw96 Dec 27, 2007
    Is there a way to check this fuse to see if it is indeed the problem?
    It looks intact with no signs of malfunction. Also if it is that fuse
    any ideas of what type of dollar range for the part, and labor would I
    be looking at? I don't mind paying but would like to know if I'm taking
    a beating. Thanks again
  • jw96 Jan 03, 2008
    I changed out the FL231 fuse on my RCA HD52W59 and seems to work for
    about 5 mins or so. then it warms up and goes to just green then black
    screen. after sitting awhile it will go on again then do the
    same. Any Ideas?
  • mhumphrey12 Jul 11, 2008
    i was on the other day and saw jw96's blog about FL231 - i pulled the back of and then found this little ****** and when I pulled on the top of it - it came off and what do you know - it is indeed blown - it appears to be a small fuse - however I am having trouble getting the board out to be able to get to the under side to get the guts out and replace it - has anyone else done this yet? way too small to jumper this thing - i did go on mouser also and searched T400mA - that shows as a converter not a I missing something here?
  • 1,030 Answers
There is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Posted on Dec 27, 2007
  • Willie Howell Dec 27, 2007
    FL231 Is a small rectangular fuse and will not show signs outside visible to eye next to flybacke there are 3 small brown box like components. the others are fl221 and fl252 the one in the middle is the one that cause that. checking them is difficult you have to pull the chassis out and up to get to bottom then the points are under some plastic cross peices ..before you go through that trouble. go to setup in customer menu ..wait you done that and you had no convergence. it still could be convergence power or amp board. our shop charges around 125 to 250 for such a repair. maybe you can find a tech to just check that fuse to begin with.
  • 3 Answers
Replace FL231, middle fuse (Check all 3 fuses). Check solder connections on Flyback, lead free solder is is very brittle and can't take the heat generated by the flyback transformer and cracks. This increases the overall resistance of the circuit and causes the fuse to eventually blow. Resolder all of the flyback connections with leaded solder, remove as much of the lead free solder as possible with a solder ****** or solder braid before applying lead solder. This will improve the ovall quality of the solder connections as old solder is just that "old solder" also the lead free and leaded solders do not mix well and will weaken the solder joint.
Posted on Jan 19, 2010
Tin foil works great. Just rig it up by jumping the fuses with foil. Should work like a charm. That's the redneck repairman way to do it.
Posted on Mar 15, 2011
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Screeen is bowed and i have a ghost or 3d effect on the screen. the tubes may need to be converged, but not sure how.
This RCA DLP tv model have auto convergence at it menu,lost it from the menu or can't get to converge,this tv have a convergence fuse mean the convergence fuse FL(231) near the FBT-flyback tranformer is dead.U have a soldering iron,a roll of desodering braid or a desoldering pump and a roll of solders,also can do basic soldering.Try website like to buy a convergence fuse(FL231) to do the replacement.
Feb 07, 2011 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at and has complete instructions on CD
Oct 07, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
step by step instructions are avalable in the tips and tricks section of this website.
May 29, 2009 | RCA HD52W59 HDTV Projection Television
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
May 28, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52549. I love this TV, but
Try adjusting the convergence in the customer menu. If you can't adjust the colors then you may need to have convergence amplifiers. A professional can do this. Check around for price.
Apr 08, 2009 | RCA HD52W59 HDTV Projection Television
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
2,878 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
