Question about Microwave Ovens
Kenmore microwave mod. # 721.62463200 Fire
While making popcorn a fire started inside the wall of the unit. It melted the paint and blackened the area. Good thing I was close by and it was on for only a short time, I hate to thing what might have happened had I set it for a longer duration and left the area. There is a metal panel on the side that is removable. Looking inside there is a plug in cylinder that has a hole burned in it. What is the problem and can it be fixed? I also saw some other units were recently recalled. Any info on this unit?
  • Anonymous Feb 12, 2008
    I have attempted to repair by replacing the magnetron. This did not repair the problem. My next step will be to replace the capacitor. If this does not fix the problem, I will then replace the transformer.
  • tfsmithwv Jul 26, 2008
    Mine still works. The plate is fried. Need to find the plate. tfs
    Top Expert:
  • Microwave Ovens Master
  • 28,460 Answers
This sort of thing is caused by food particles burning and maybe the wave guide cover has a hole in it. They do not, if used correctly, burn as you describe.
Posted on May 19, 2017
MicrowaveSvc
  • 9128 Answers
SOURCE: sparking fire inside the microwave - Knemore Model No. 721.80522500
If the sparking has stopped, that should be fine.
If you have a burned spot you may need to sand it and repaint it with appliance paint from Wal-Mart, etc.
You can probably replace the shelf bracket / hook if it's still available.
If you'll post your brand and model, we'll see if we can steer you toward a source for a new shelf bracket.
If it's a Kenmore, you can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
techman
  • 3130 Answers
SOURCE: lightning inside microwave oven
You better be carefull my friend or you will start glowing in the dark!! LOL Just kidding. But I wont kid about how dangerous that metal cylinder can be with the holes in the top. Thats the magnatron. It has very high voltage going to it and you should never ever touch any wires going to it even if its unplugged as theres a capacitor in there that holds a charge for a time. f the oven is over several years old, Im sure the magnatron will cost more then a new oven, after you add labor and such. It just migfht be time to upgrade to a new microwave?? Good Luck
Posted on Aug 11, 2006
SOURCE: Small 10 sec fire in microwave
Whirlpool had a recall on many microwaves due to this problem. Call Whirlpool and see if yours is one of them. My microwave model was mh7140xfb and was on the recall list.
Posted on Dec 29, 2008
  • 140 Answers
SOURCE: microwave smells of electrical fire
The magnetron inside the microwave is starting to short out to ground. This happens after use there are small minute cracks on the body of the magnetron and those small cracks are big enough for 15,000 volts and up to 30,000 volts to leak through and arc to ground. It is not a small short but a big one. Replace the magnetron before it burns holes inside your microwave. Replacing the magnetron if you can find it locally or through the internet is pretty straightforward. Unplug the microwave and take the cover off about 6 screws. On the same side as the control panel and right behind it you will find the microwave on top. It is held in place with only three to four big screws. It will have about 4 wires with terminals on them that plug into a couple of places one being the large capacitor that stores all the voltage and discharges it through the magnetron. Take the terminals off and I always recommend with some needle nose pliers with insulated handles. There is nothing to unsolder and to solder. Its like replacing the battery in your car or the electronic module. Take care and good luck.
Posted on Jan 22, 2009
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
Why does microwave turn itself off occasionally after a minute or two
There is a fan inside that blows air across the electromagnet that cooks your food. It gets hot! The fan is most likely broken or spinning to slow to keep the electromagnet cool enough. There is a thermal sensor on the electromagnet to shut off the oven if it gets to hot to prevent it from catching on fire or melting everything inside the oven control area.
Nov 02, 2017 | In Microwave Ovens
Why did it catch on fire?
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Nov 15, 2015 | Microwave Ovens
Need to paint the inside of my 2001/240 v. Ge advanium what do you recommed
I wouldn't recommend painting it. The inside of the microwave is a box that allows microwaves to bounce around off those walls. If you paint the inside of your box you could have a serious fire hazard. I would send and e-mail to GE and see if they recommend anything that is microwave safe.
Mar 26, 2015 | GE Microwave Ovens
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Microwave sparks and makes noise only when fixing microwave popcorn. Otherwise, microwave works fine. The microwave previously worked fine with microwave popcorn. This happened with another brand of...
Hello bruton. As a microwave oven ages, the interior paint often deteriorates as does the internal part that creates the micro waves.
Using this is not a good idea as there is now a fire hazard. The best solution is to replace the microwave. There are sales now and you can get a nice new one for under $100.
Joe
Thanks for choosing Fixya!
Mar 23, 2011 | Microwave Ovens
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
Microwave about 3 years old. Started making a bag of popcorn and after about 1 min. the unit started making a sizzling and grinding sound and a puff of smoke was noticed at the inside right panel opening....
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the oven wall is burned or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth, then apply paint.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
May 27, 2010 | GE JES1384SF Microwave Oven
Over heating and shuting off
I am not surprised! Cloth of anysort is not recommended to be placed in a microwave oven!
That includes undies and socks which many try to speed the drying time of.
Regarding the popcorn.. The oven is overheating due to a possible containment in a hutch, where insufficient airflow is available to lower the temperature. Pull the unit away from the wall to allow more airflow, clean the vents and help it breathe.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is making a loud buzzing noise and there was some charred areas inside on side wall
The loud noise is probably the magnetron makign the noise. The charred areas on the wall are from possible grease or food particles arching and burning the cavity. Alot of times there is a cover on the wall it burns. it would need to be replaced, as well as sand and paint the cavity area that is damaged with m/w grade paint.
Nov 21, 2009 | Thermador MBBS Microwave Oven
Microwave Ovens Logo
803 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
