Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
Ice in bottom of freezer
The refrigerator side of my side by side seems to work fine but the bottom of my freezer has a huge block of ice in it. I don't know where the water is comming from we haven't even hooked up a water line for the ice maker of dispenser yet. Is this a simple fix or do I need to get a whole new one?
  • Bill Paxton
    Bill Paxton Sep 06, 2008
    Mine is doing the same thing. Looks like the water is coming from behind a grill in the back of the freezer about a foot from the bottom. I just got the ice out and am starting it back up with the freezer empty to make sure. After seeing exactly where is comes from I'll remove this grill to investigate.
Same thing - but I can't get the grill out. I have removed the fasterners, but it seems anchored at the bottom. It's not frozen, I thawed it out. Anyone know how to get this thing out?
Posted on Aug 17, 2009
    Sergeant:
  • 263 Answers
That is because your compressor it does not have the pressure the one requires at this time let me try to explain this.... iside your lines there is oil and gas may be f12 ,f34 or diferente ok the only way to make the gas circulate on your sistem is with pressure that pressure is done with the compressor or motor, inside the compressor it has valves they are call flapers so because they are made of on steel and they are open and close so many times for second they can be wear out on some mechanic components inside the compressor that make the pressure by pumping it thru the lines to the condenser thru the evaporator and return to the compressor deposit and then again ...so when that hapens there is not enough pressure and that condensation is just ride there on botton of your freezer way to fix you may be able to add more gas to compansate or replace the compressor and refill the sistem how did you see the info
Posted on Dec 27, 2007
Why is my GE side by side freezer not freezing on top?
It sounds like the freezer fan has failed. You are correct on the ice machine.
Jul 21, 2014 | General Electric GE Profile PSDS3YGXSS...
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerator side is not cooling
You have a defrost drain blocked and a possible defrost problem with your refrigerator. Need you to get me the model number as shown in the photo locations below. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 16, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator not cool
Hi, if the freezer has ice on the bottom, you nees to clear the drain hole.
Remove the rear panel and remove all the ice. After the ice is out of the drain hole, try and flush it real god (baisting seringe works great) with hot water. If I can assist you further, please let me know.
Thanks
Vic
May 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking ice maker
check tube in back of ice maker to see if it is all the way in
May 08, 2009 | Refrigerators
Freezer compartment not cooling
Di a total defrost and remove the back wall cover from the freezer. Look for ice buildup in the cooling fins. If the air channel is blocked, you won't get proper freezing.
Mar 23, 2009 | GE Refrigerators
Upright freezer is leakng from the bottom of the door
pull out lower bin and check at back to see if you have ice build up. if you do the defrost drain tube is blocked
Dec 15, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
15 year old Kenmore side by side refrigerator
I had the same problem and had to have serveral parts replaced, it was very expensive $600.
Good Luck
Kathy
Sep 21, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
116 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
